XBR-65x850e Sony, no power questions
  • EazyBone
    • Jun 2023
    • 1350
    • United states
    I got this tv above, has no power. I suspect emmc corruption and might have to send board out because I cannot do it. But I am trying to test panel first and having some confusion on the numbering done for the PSU connector. Can someone shed light on how this is numbered as things don't seem to match up to me.
    Does it start row 1 (bottom of connector on top) as number 1, then go to row 2 as number 2 and then cycle 3 is number 2 on bottom and 4 is number 2 on top?
    I would like to jump tcon on etc to test panel but for some reason the numbering is off to me. My experience says tcon on is the white wire running to tcon which says number 26 but, that numbering doesn't make sense since there would be 30 pins and not 28. Hope it makes sense.
  • Diah
    • Feb 2013
    • 6399
    where are the problem...? on the socket 2 Row Odd Numbers Row and even number row. so Odd row 1-3-5-7-9-11-13-15-17-19-21-23-25-27 , & the Even Row 2-4-6-8-10-12-14-16-18-20-22-24-26-28
    • EazyBone
      • Jun 2023
      • 1350
      • United states
      So this grey wire in new picture is tcon on then? 26. I feel like the white wire was tcon on before, I guess that's not the case?
      I don't want to blow something up like an idiot. And for some reason I am confused
      • Diah
        • Feb 2013
        • 6399
        t-con ON pin 26 mean the even row before the last one LOL if you afraid of mistake use R 1K Ohm between Jumpers
        • EazyBone
          • Jun 2023
          • 1350
          • United states
          When I jump ps on, 3.3stby and blon, backlight doesn't come on at all. Is there something else I need to jump to get it to come on? I've tested all the lights so they do work.
          any suggestions would be helpful, first pic shows pins
          • Diah
            • Feb 2013
            • 6399
            show the whole back of the TV.... you have 3 Zone of DIMM,, when you did STB to Poo /TCON_ON /BL-ON did you checked the BL error going high or not
            • EazyBone
              • Jun 2023
              • 1350
              • United states
              So it's a edgelit tv, LED tester lights up 4 spots for 1/4 of screen.
              Bl err does not give any voltage when jumpered as you ask. Stays at zero
              As an alternative test, I just jumpered PSON, stby 3, tcon on, and then used LED tester for backlights (1/4 screen) and that corner lights up but I also get no image on the screen either. (PSU disc from MB and MB to tcon ribbons disc at tcon also)
              I expected it to cycle RGB like the other sonys I've tested
              • Diah
                • Feb 2013
                • 6399
                same test you did. remove the 2 LVDS from T-CON side...... remove the metal shield ( don't forget to screw the t-con to chassis ) to have access to T-CON fuse for test 12V from both side
                • EazyBone
                  • Jun 2023
                  • 1350
                  • United states
                  I was able to test fuse with shield on, I get 12v each side. I removed the shield already to check lvds because it had been opened and maybe not connected but the shield hasn't been off before
                  As a note, I got this TV free and it had previously been opened. Didn't get any data on that, but the lvds from main to tcon was disconnected when I first opened it up
                  • EazyBone
                    • Jun 2023
                    • 1350
                    • United states
                    Any other thoughts anyone? If I can't test the panel or anything going to scrap this TV as $110 is a bit to much to throw at this without knowing.
                    • Diah
                      • Feb 2013
                      • 6399
                      same way last test but let the panel half ribbon connected or look after edge boards U ribbon to disconnected from each side a time
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4367
                        • Italy - Milan
                        You very not practical.. TCON12V powers MB first and this powers TCON.. if MB is disconnected.. let you think...
                        you have to jumper (without resistors) STB3.3V - Power-ON - BL-ON, then fly a jumper wire from REG12V to Fuse on TCON, the strange is why BL doesn't glow.. at last try a 2k2 ohm from stb3.3 to DC-dimmer
                          • 12206
                          • U.S.
                          Check D750 thru D753 for shorts.
                            • 12206
                            • U.S.
                            So tv seems dead, no indicator light on front?
                            • EazyBone
                              • Jun 2023
                              • 1350
                              • United states
                              Yea sorry, I put it to side for moment as parts for other tvs came in an need room.
                              Yes no indicator light, PSU seems fine.
                              Yea why BL doesn't come on is odd, I didn't use any resistors to jump anything. But I'll take a look at all suggestions.
                              I will get back to this thread with tests after I clear out some TVs, got way too many at moment and need some space before back to this. Will update in a week or so.
                              • EazyBone
                                • Jun 2023
                                • 1350
                                • United states
                                Lo and behold I still have the TV and got a half working board that also needs repair.. stuck it in and image and sound everything works. Unsure what specifically is broken but going to probably send out the board to repair.
                                Does anyone have the EMMC file for this TV? I read lotas said Id is linked to something but if repair shops can fix it, how are they doing it.
                                • EazyBone
                                  • Jun 2023
                                  • 1350
                                  • United states
                                  Additional update. The new board I got is for a 65x900e not a 65x850e
                                  The customer said he replaced the main board (which is why it's x900e) and it worked for a long time until now.
                                  Are these boards interchangeable? Someone have this data?
                                  • Daren87
                                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                    by Daren87
                                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                    08-13-2023, 03:25 PM
                                  • thelankanguy
                                    Sony KD-55X9000F TCON Issue
                                    by thelankanguy
                                    The TV shows a black screen with no image.
                                    TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                    Later both ribbons were disconnected and TCON voltages were tested.
                                    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                    There is also a short to ground in this circled inductor.
                                    Is this a TCON issue or something else ?...
                                    12-13-2024, 12:27 AM
                                  • bbrain
                                    Sony KD-55AG9 TCON?
                                    by bbrain
                                    I have this problem with my Sony 55' AG9.
                                    It flashes 4x.
                                    I have found the service manual, and seems it is the TCON.
                                    Before I buy a TCON can someone check the vid?
                                    Thanks in advance!...
                                    09-19-2024, 10:50 AM
                                  • rimwall
                                    Sony KD-65x8500b - bad Tcon or panel?
                                    by rimwall
                                    Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                                    a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                                    b) the Tcon board is malfunctioning,...
                                    10-24-2023, 07:58 PM
                                  • x_orange90_x
                                    TCL 50S535 bad tcon or panel issue?
                                    by x_orange90_x
                                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                    03-29-2025, 11:02 PM
