JVC LT-40V750 stuck in service mode switching colors.
  • thesame
    • Mar 2018
    • 121
    • Romania
    The tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?
    • 12097
    • U.S.
    Try holding in the power button on tv, hold it til the screen changes, shouldn't take more than a minute if it's going to work.
    • thesame
      thesame commented
      Editing a comment
      I have tryed it , i've holded the power wheel for 1 full minute with the tv off and it was keep restarting, and i have also tryed holding it while the tv was on but still no change.
  • yokoono
    • Apr 2010
    • 479
    Clean the contacts from the lvds ribbon.​
    • thesame
      thesame commented
      Editing a comment
      I have just cleaned it , nothing changed.
    • 12097
    • U.S.
    Could try a firmware update, had an old sony with same symptom, update fixed it, some tvs you need to select things with remote to continue update, this old sony kdl did not, you just plug in usb drive and turn on tv, when it was done the front led changed to a solid color, took about 30 minutes. Important to make sure it's done, could brick tv if an update is interrupted before it's finished.
    • Diah
      • Feb 2013
      • 6355
      its much like you have broken contact pins on the LVDS ,, need to inspect carefully... if they are 100% fine... then from any firmware for 17MB97..use only the script txt file.... and comment all # till the end keep only the line reset
      • yokoono
        • Apr 2010
        • 479
        Panel is VES400UNDS-2D-N11 ?.
        • thesame
          thesame commented
          Editing a comment
          Yes, that is the pannel model.
      • yokoono
        • Apr 2010
        • 479
        Stick firmware. Try at your own risk. If the remote control no longer works, use a programmable one.​ Cred ca stii procedura de instalare.
        https://files.fm/u/47jm44yhnz
        • thesame
          thesame commented
          Editing a comment
          Thank you, da multumesc frumos.
      • thesame
        • Mar 2018
        • 121
        • Romania
        Quick update, i found another 17MB97 good working board, and the pannel acts the same with the donor board switching colors.
        • vinceroger69
          • Mar 2012
          • 6714
          faulty t con board maybe
          • Diah
            • Feb 2013
            • 6355
            never.... damaged lvds or its sockt
              • 12097
              • U.S.
              Maybe check if lvds cable has continuity from end to end.
              • thesame
                • Mar 2018
                • 121
                • Romania
                I may have found the culprit . Click image for larger version
                • vinceroger69
                  • Mar 2012
                  • 6714
                  yes that will do it
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Thanks diah im still learning hence i mentioned maybe.
                      • 12097
                      • U.S.
                      Looks like a solder blob, wonder how that got there.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        i thought maybe a screw hole
                        • lotas
                          • Jan 2016
                          • 4536
                          • Russia
                          A bolt was inserted longer than necessary or it was tightened without a stand and the bolt damaged the cable.
                          • thesame
                            • Mar 2018
                            • 121
                            • Romania
                            Problem solved, by replacing the lvds flex, the owner just realized when i told him that he tryed to fix it on the holder and he put one of the screw in the wrong hole.
                              • 12097
                              • U.S.
                              Ok, I thought someone must have put a long screw thru it, it's a hole, when I clicked the picture to enlarge it, looked like a solder blob with a tip on it but just an optical illusion.
                                LCD LED TV Service Menu Codes
                                ALL LCD LED TV SERVICE MENU CODES
                                Service Menu Code with Board Name
                                China Universal Board / Jumper Board Service Menu Code
                                Changhong Ruba Service Menu Code
                                Ecostar LED TV Service Menu Code
                                Orient LED TV Service Menu Code
                                Haier LED TV Service Menu Code
                                TCL LED TV Service Menu Code
                                Samsung LED TV Service Menu Code
                                LG LED TV Service Menu Code
                                Videocon LED TV Service Menu Code
                                Supra LED TV Service Menu Code
                                Toshiba LED TV Service Menu Code
                                Symphony LED TV Service Menu Code
                                Veste/ LED TV Service Menu Code...
                                10-31-2024, 03:58 AM
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                                Acer Aspire A517-52-33HD + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
                                This specification for the Acer Aspire A517-52-33HD + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52-33HD + Extended Service Plans boardview and A517-52-33HD + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                09-07-2024, 02:20 AM
                                Acer Aspire A315-56-32Y4 + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                                This specification for the Acer Aspire A315-56-32Y4 + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-56-32Y4 + Extended Service Plans boardview and A315-56-32Y4 + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
