bush lcds20tv002
  • vinceroger69
    • Mar 2012
    • 6714
    bush lcds20tv002
    another freecyle freebie a nice easy fix did not even open the set up was a faulty psu brick replaced with a 12 volt 5 amp brick (as per rear of set sticker) works great old psu brick was ticking under load not modern as no freeview or hdmi but will do some one i guess even had the stand was a bonus just going to order a remote for it.
    Re: bush lcds20tv002
    If you want to fix that old brick it's probably a shorted diode or bad start up capacitor 99% of the time, then you'll have a spare. I had same fault with a small 19" Baird.
    • vinceroger69
      • Mar 2012
      • 6714
      yes i will do need a cutting disk for my dremil lol to open it i used my spare one for now the round 4 pin type whatever there called will this remote control work it as a educated guess?
      http://www.ebay.co.uk/itm/2713505383...84.m1439.l2649
        As bush products are made by the lowest bidder on that particular day they are pretty much incompatible with each other in most cases, maybe it has a code but I would not expect it.
        • vinceroger69
          • Mar 2012
          • 6714
          well maybe worth a try i did not think of that to be honest will remember next time though as i brought it before i asked you lol will update u soon to let u know if it worked basically only need it to switch on volume and scart input as no hdmi or freeview involved has a menue button the set does the other items needed loads on my freecycle site at the moment have you checked yours out tom
            Try URC3940, from One-4-All, they are available for about £6 and have many codes. Have worked with all branded TVs I have tried too.
            • vinceroger69
              • Mar 2012
              • 6714
              i had one of them in my watch list lol you may of mentioned that before then and i kept the link.do they also do the freeview programming on lcd sets?
                Yeah they have a Guide and Menu button, arrow keys work. Only button they miss is Back -- exit works, but it takes you right out of all of the menus. I was even able to get smart features working on a Toshiba.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  cool will buy one then thanks
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    guys any idea what the 4 pin round plug is called i need to order one from cpc cheers
                    http://www.ebay.co.uk/itm/Bush-LCDS2...item2ec7ac85f1
                    • selldoor
                      Slow Learner
                      • 7870
                      4 pin DC Connector?
                      They seem to come in different sizes and pin configuration
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        cheers selldoor this is the exact plug i need was going to try cpc as will be cheaper hahaha
                        http://www.ebay.co.uk/itm/4-Pin-TFT-...item4cf5eb03bc
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          just to say this remote from ebay works all functions fine with no codes having to be entered it also comes with a code manual for all different bush types and 2 Duracell battery's so its a good price and comes boxed etc.
                          • FlailingEngineer
                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                            by FlailingEngineer
                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                            05-31-2023, 06:52 AM
                          • spleenharvester
                            GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                            by spleenharvester
                            I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                            07-08-2025, 06:02 PM
                          • UADmytro
                            Lenovo T14 Gen1 i7 10  nm-C931 (brick)
                            by UADmytro
                            Hey! I bought a Lenovo T14 Gen1 i7 10 nm-C931 (a brick). The previous owner said he got it on eBay as a password-locked device and took it to a repair service, where they tried flashing something. The result: it doesn't turn on.
                            When I plug in the charger, the charging LED lights up, and the power button indicator blinks three times.
                            I downloaded the firmware from the official website, but it's incomplete. However, there is a firmware for the embedded controller (MEC1663). I did a mass erase via OpenOCD, wiped MEC1663 along with the EEPROM, and flashed an image from the...
                            03-23-2025, 03:45 AM
                          • tyler123456
                            Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                            by tyler123456
                            Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                            I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                            I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                            Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                            Anyone...
                            08-16-2024, 12:51 PM
                          • Johnny.p
                            Bush WI-1810 Internet Radio
                            by Johnny.p
                            I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
                            U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
                            11-25-2023, 04:18 AM
