Digihome 32" LED TV
    • 31187
    Re: Digihome 32" LED TV
    • jpensar
      • Oct 2015
      • Finland
      #42
      I have an issue with a Philips 32PFL3008T, where the power board type is 17IPS19-5P. The TV is working, but I get no backlight (i.e. screen looks black but shows content when lit by flashlight). Is it the same powerboard that handles the backlight and do the advice in this thread apply?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        #43
        Possibly Led failure do you have 24v ?
        • 6gv5
          • Nov 2015
          • Italy
          #44
          I have this same power supply board used in a Telefunken set relatives gave to me to attempt repair. Same problem here: TV is dead.
          So far I've found the schematics here.
          http://elektrotanya.com/vestel_17ips.../download.html
          But be aware that the board we have (mine is identical to the pic posted here) is a bit different from the schematic: they simplified the circuit and omitted some parts to save costs, so it becomes harder to nail problems.
          • foxgw
            • Dec 2015
            • italy
            #45
            Hi guys i have a faulty Vestel 17IPS19-5 installed in a Hitachi 32XHC01.The initial situation was a tv completely dead. After replacing the three top diodes SB5B0 (one was bad) the tv turns on again but i still have a little problem, a loud buzzing noise coming from the L502 component,
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              Turn down the brightness see if it goes.
              • foxgw
                • Dec 2015
                • italy
                #47
                Nothing changes, the noise is still there constant
                • tmcw
                  • Oct 2010
                  • 382
                  • Ireland
                  #48
                  Just to add to the great info above, another Vestel 17IPS19-3 here, in a Finlux 26" FIN26LEDHDR, with the 3 SB5B0's at the top, and 3 UF5402's towards the bottom.
                  Found one of the SB5B0's (nearest the transformer) to be shorted, the other 2 were ok. Replaced the shorted one with an SB5100, and the TV powers up ok. Will replace all 3 with SB5100's.
                  Haven't tested the 3 UF5408's. Has anyone found any of these to be shorted at any time? Might leave them if not. The set is easy to work on if they do eventually need to be done.
                  • Anor1412
                    • Dec 2017
                    • 22
                    • England
                    #49
                    Hi all had the same problem the diodes are coming out at 0.00 - 0.02 up and down. I noticed this isn't a very recent thread but I usually get my diodes at work and have never had to actually go out and buy them. I've tried an online search for where to buy the diodes for this board and have so far come up with squat. Can anyone help?
                    • Anor1412
                      • Dec 2017
                      • 22
                      • England
                      #50
                      Wow ok didn't click all the way to the last page so I'm referring to the vestel 17ips19-3 board from an earlier post
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #51
                        Originally posted by Anor1412
                        Hi all had the same problem the diodes are coming out at 0.00 - 0.02 up and down. I noticed this isn’t a very recent thread but I usually get my diodes at work and have never had to actually go out and buy them. I’ve tried an online search for where to buy the diodes for this board and have so far come up with squat. Can anyone help?
                        https://www.ebay.co.uk/itm/10x-SR510...UAAOSwiDFYLlxI
                        http://www.ebay.co.uk/itm/10-x-UF540...4AAOSwYS9ZYkTS
                        • Anor1412
                          • Dec 2017
                          • 22
                          • England
                          #52
                          Wow haha that was a fast response I didn't think of eBay cheers for that tho I really appreciate it
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #53
                            i try to use the likes of rs or cpc for parts but most have minimum orders so yes ebay is ok for the odd orders like this your local maplin store may have these parts in too some stores are better than others though.
                            • Anor1412
                              • Dec 2017
                              • 22
                              • England
                              #54
                              Thanks again I tried maplin but they said they couldn't help so thank you I'll bare that in mind for the future
                              • dcbw
                                PowerMac G5 ACBel 614-0303 buzzing
                                by dcbw
                                The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
                                The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
                                Other info: API2FS34, ID 291, Date B0404
                                05-31-2024, 07:13 AM
                              • heathloder
                                Sony XBR-65X850E - has standby 3.3V, but won't power on - no status lights
                                by heathloder
                                I have a Sony XBR-65X850E that won't power on, and has no status lights.
                                Immediately upon plugging in the TV, it tries to power up (before pressing anything). I can tell because after plugging the TV in, the main transformer on the power board begins buzzing, 2 seconds on, 2 seconds off, and it does this exactly 7 times before the TV goes back to an “OFF” state. If I press the power button on the TV, the same cycle repeats. I can confirm that no ‘status' LED's are lighting up when this happens. The backlights also do not turn on, but I can confirm that they at least “light...
                                04-04-2020, 07:36 PM
                              • novator2007
                                Help with finding ThinkPad T460 JTAG Points
                                by novator2007
                                Hello All,
                                I got a T460 with issue - No picture - Fan on full Speed and no Power LED Light.
                                Bios already reflashed
                                All standard voltage is present. CPU on emergeny(?) mode - max 30 c Grad.
                                By Schematc & BRD View I have found few Debug/Jtag points.
                                Just not sure which one is correct,
                                1.There is some(under lack) Test points near CPU - Schematic Page 6
                                2. J9 26p place for connector - Present: PCH_TMS/TDI/TDO/TCK/RSMRST
                                3. J8 26p place for Connector - XDP_TMS/TDI/TDO/TCK/RSMRST
                                I trying to find a correct...
                                08-02-2022, 07:49 AM
                              • reessi
                                Hanns-G HG281D - LCD Monitor - Low B/L voltage and loud buzzing...
                                by reessi
                                The pics are off the other really long thread as they are much clearer than my phone will do.
                                The fault:
                                In standby there is no buzzing.
                                After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
                                It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
                                If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
                                I have checked every single cap on the psu and logic board by un-soldering...
                                07-05-2020, 05:23 AM
                              • howardc64
                                LG 65UQ8000AUB no backlight burning smell
                                by howardc64
                                Only 3 years old. Owner said backlight went out and burning smell. Didn't bother plugging in to check if had power LED. Just opened the TV rear and found shorted bridge rectifier diode on the backlight circuit on the PSU. SF26G (400V 2A super fast recovery rectifier link ) diode replace with SF26 (what I had on hand) Google AI said G = Green Components.
                                Burn looked pretty bad on the board but just was blackened carbon coating material. Scraped and cleaned off quite well and clean solder pad for the new diode.
                                06-07-2025, 10:38 PM
