PowerMac G5 ACBel 614-0303 buzzing
  • dcbw
    • May 2024
    The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
    The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
    Other info: API2FS34, ID 291, Date B0404
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
  • Snownomow
    PowerMac G4 MDD ACBel Power Supply issues (API1PC36 400W)
    by Snownomow
    Hello!
    First want to thank folks on this forum (Toasty, etc) for the very useful info I've found here that has allowed me to repair a PowerMac G4 MDD Samsung power supply and get this ACBel one working better!
    I got a PowerMac G4 MDD for free as it was dead (not booting at all). I was able to confirm it was it's ACBel power supply as another (above mentioned Samsung) power supply works ok with the system.
    With this ACBel power supply installed, the system would not boot at all, no power light blink, nothing. I've gone ahead and replaced the "12...
    07-18-2020, 04:56 PM
  • Baldrick
    Crest CKS400 Amp - Buzzing Relay
    by Baldrick
    Hi all. I've got a Crest CKS400 amp that's got a buzzing power relay.
    Originally, the relay would buzz until the unit was turned off. Now, it buzzes for a second and stops. The relay also shows a blue spark when first powered.
    My question is, is it likely this is just a bad relay (Potter & Brumfield K10P-11A15-120) or do you thing it's something else making the relay lose it's mind?
    Thanks!
    04-22-2020, 08:27 AM
  • Snownomow
    Shock when touching power supply case (ACBel API1PC36 from PowerMac G4 MDD)
    by Snownomow
    Hello!
    I recently successfully repaired two Apple PowerMac G4 MDD power supplies by swapping out bad caps, per excellent info found in various threads on this forum - yay!
    I was doing testing on one of them, the ACBel API1PC36, with it's case open and had it setup outside of the PowerMac resting on the table with it's power connected to the system (power was also connected to a couple SCSI HDD drives, for a bit extra load). It was working fine, I shut down the system but did not unplug the PS from the power strip (and power strip was left on) so power was going into...
    07-30-2020, 02:20 PM
  • jm1234
    9V relay temperature 40C
    by jm1234
    Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
    I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
    05-09-2024, 03:03 AM
