I got a Panasonic TX-P37X20B with no power and 13 red LED flashes. A google serch says it's a emergency sos on the "A" board which is the main av board. Is there a text I can do to prove this? I disconnected the y and x boards but same problem remains. The power board isn't giving any secrets as to voltages to check.
Tags: None
Re: Panasonic TX-P37X20B
Sounds like A board. P42C2E, same A board and PSU SOS 13I got a Panasonic TX-P37X20B with no power and 13 red LED flashes. A google serch says it's a emergency sos on the "A" board which is the main av board. Is there a text I can do to prove this? I disconnected the y and x boards but same problem remains. The power board isn't giving any secrets as to voltages to check.
That A board looks worked on? that white connector with no plug in center top, is that badly corroded / shorting? -
Its a pretty new set, very clean inside. the connector is not corroded see pic.
I got some blinking information (pardon the pun) on the led flashes codes in case someone needs it in the future.
BLINKS PROBLEM CHECK POINT
1 blink Panel Info SOS * No Info Given *
LP1 Start SOS
3 blinks P+ 3.3v SOS A-Board
4 blinks Power SOS P Main-Board / P Sub-Board
P-Board / P2-Board
5 blinks P+ 5v SOS A-Board
6 blinks Driver SOS 1 SC-Board / A-SC FPC
SC Energy Recovery Circuit
A-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board / SS FPC / SS2 FPC
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS A-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P Main-Board / P Sub-Board
Tuner Power SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker / Woofer
13 blinks Emergency SOS A-Board
14 blinks IR LED SOS A-Board
BOARDS DESCRIPTION:
P MAIN Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P SUB Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P Board = Power Supply (All Other Models)
P2 Board = Power Supply (All Other Models)
A Board = Main AV Input / Processing
K Board = Remote Receiver / Power LED / C.A.T.S. Sensor
S Board = Power Switch
V Board = 3D Eyewear Transmitter
C1 Board = Data Driver (Lower Right)
C2 Board = Data Driver (Lower Center)
C3 Board = Data Driver (Lower Left)
SC Board = Scan Drive
SS Board = Sustain Drive
SS2 Board = Sustain Out (Lower)
SU Board = Scan Out (Upper) - Non serviceable. Must be replaced for service.
SD Board = Scan Out (Lower) - Non serviceable. Must be replaced for service.Attached Filesif you find these attachements useful please consider making a small donation to the site
Those blink codes are from what manual? I'd expect the SOS the same for the 42 and the 37 since they both have the same TNPH0829 A board the difference should be just the data loaded on the eeproms/flash ics.
Don't see 13 blink, stops at 12 but probably does not mean it can't generate a 13 blink, just not mentioned. that post I linked has the same A and he reported 13, new A board fixed it.
Yeah, second shot much clearer of that connector, looked funny in the earlier shots.Last edited by tw2005; 01-02-2014, 08:46 AM.Comment
Actually, 13 blinks was sounding familiar to me. I have a 42X20A, same generation, different A board TNPH0840 but very similar.
During an eeprom swap/conversion I created a 13 blink, mine stops at 12 in the manual too.
This is what I wrote "After doing all 4 I had SOS9-discharge control SOS, A-board. Looking at the cct I went for IC9304, swapped the other 42" FHD IC9304 - 13 blink- no such code.
Rechecked my work, found bridged resistor pack R8922 which sits right next to 48pin IC8921 NAND Flash- must have brushed it with the tip."
If I was going to have a guess, IC8921 on yours might be bad or corrupted or maybe a power supply issue to it, 3.3 volts supplied at pins 12, 37, gnd at 36,13. Page 50 in that manual.
I think it may be hiding under the alloy heatsink on yours or underside. 48pin , thin rectangular chip. may have a white label with TVRR431 on it.Comment
The codes are from this web site. http://www.highdefjunkies.com/plasma...on-thread.html
I've ordered a main board off ebay. cross fingers.Comment
I've done this on that model whilst I was mucking around with the chips, if you remove the 3 white ribbons, I also disconnected vsus from SC,Ss and P35 for vda to the c boards, power up the Tv and if it still blinks 13 in this case it has to be the A board, I don't think it could come from anywhere else really.Comment
Yeah, so it's the 2010 list you should go by not the 2011 but I reckon it will be a comms issue on the A , which is how they expand on that 13 blink in one of the 2011 guides I looked at.The codes are from this web site. http://www.highdefjunkies.com/plasma...on-thread.html
Flip latch and pull lightly on the cable. Very lightly.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I disconnected the 3 ribbon cables and the p35 cable but where is the vsus from SC,Ss .Comment
update, I put a new "2nd hand off ebay" board in and now im getting 4 red blinks instead of 13Comment
So you've got a double fault but surprised the SOS 4 did not show previous, maybe the faulty A was unable to process it.
has this got a TNPA5072 SS board? Most likely shorted vsus.Comment
I missed your P2 question but if the power was removed from the Sc,SS, ribbons removed and p 35 disconnected then The A was faulty.
I had the same deal but in reverse for my 42X20. had SOS4 (shorted SS) then cleared that and ended up with SOS1 A board. I must say that sucks getting a double whammy.
Edit:
So that would be P2/SC2, P11/SS11, P35, 3 white ribbons disconnected power on and still have 13 blinks.
Hope you don't tell me the SS was still connected when you did the test.Last edited by tw2005; 01-06-2014, 04:49 AM.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by BiruslapioHello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
