T-Con Problem but No T-Con Board? Sony 40CX520
  • max1636
    • Dec 2013
    • 80
    I've got a Sony 40CX520 with a typical T-Con looking problem. The screen is blue all over and the image ghosts at times on the screen as seen here:
    http://i1208.photobucket.com/albums/...psc80d5de0.jpg
    So it's a T-Con like problem but the TV has no T-Con board as such. I don't understand why but there are boards for the same model listed on eBay here:
    http://www.ebay.com.au/itm/LVDS-T-CO...386fc0b&_uhb=1
    The connector from the main board goes straight to the board that goes to the ribbons that go to the panel itself. This is that board:
    http://i1208.photobucket.com/albums/...ps9509e788.jpg
    http://i1208.photobucket.com/albums/...ps1b4569b8.jpg
    So should I replace the main board? Or is the set not worth fixing and maybe the T-Con's job is being done by the board connected directly to the panel?
    Re: T-Con Problem but No T-Con Board? Sony 40CX520
    It's not a t-con issue. I've seen this on TVs with and without a t-con. It's a panel issue. Not repairable as far as I know. Yes the t-con is now on that unreplaceable panel board.
    • max1636
      • Dec 2013
      • 80
      That sucks oh well thanks then.
        There is a theory I have but I'm not confident on it, involving the VOFFE or VONE voltage on that panel board going missing. If you can see the test point for that you could see if they measure too low, too high or OK.
        VOFFE: -5 to -8V
        VONE: +20V to +30V
        • max1636
          • Dec 2013
          • 80
          VOFFE: -5 to -8V
          VONE: +20V to +30V
          I just realized I forgot to mention. A few times the TV switched off then came back on by itself. But I thought maybe I was shorting the main chip when I was spraying it with freeze spray. Or is freeze spray non-conductive?
          • max1636
            • Dec 2013
            • 80
            I've actually just put the set back together because I thought it was done for. I will open it back up tomorrow and see what I can find.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Freeze spray isn't conductive.
              A working TV? How boring!
                Canned air "freeze spray", on the other hand, very much is...
                • max1636
                  • Dec 2013
                  • 80
                  I bet it sounded like a dumb question didn't it haha well for some reason every now and then the set would turn off then back on by itself. Could it actually be because the chip was so cold the TV tripped out? Like an underheat if such a thing exists.
                  • ElBeat
                    • Feb 2014
                    Hello Members
                    I have the same problem with TV as max1636. I have not been treated with a freezing spray, so I think that is the reason TV does not restart itself. I've been measured VONE (28.2V) and VOFFE (-11.0V). I've been Googled around for this problem, red a thousand posts and this is the first one I've encountered for this problem. I'm really interested to hear the rest of your theory for these voltages. The TV is spilled all over the kitchen table and The-Wife-That-Must-Not-Be-Named have blessed me to do what ever it takes to fix it. I've the skills and patience but need the guidelines.
                      Since VONE and VOFFE are good (new panel VOFFE seems to be higher, this is OK) I would suggest that it would be something wrong with the actual panel drivers or panel itself; sadly, not fixable in either case. Wish I had better news.
                      • ElBeat
                        • Feb 2014
                        The panel is one month old after a two year warranty. I believe this is a problem with some kind of color driver because I've been missing blue color, Max1636-red one."Missing" is a not accurate..may be slow response (minutes instead of ms ).
                          Contact Sony - they've been sometimes willing to deal with customers a few months outside of warranty as a good will gesture.
                          • ElBeat
                            • Feb 2014
                            I spoke with a technician from the official Sony service and told me they put pads under the ribbon cable (but this is not a fix).
                            I try myself to find a solution because I have knowledge and experience in electronics but not with TVs. I do not find any components that look as drivers for various colors. I wonder if there is any block diagram or schematic how to manage the LCD screen or on a T-con board
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • huj3r
                              Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                              by huj3r
                              Hi there!
                              I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                              Photo of the situation after the black shadow dissipates:
                              After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                              I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                              > This indicates HFR Communication error. [ HFR Communication...
                              08-15-2023, 10:55 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • gersrt
                              Ordered Wrong TCON Board For Sony TV, Can I flash Epprom
                              by gersrt
                              HI
                              Made a mistake and ordered the wrong TCON board to replace in my KDL-46HX823, the board I ordered was Sony PLY 1-883-893-11 which is sort of correct.
                              But later realized this board is used in 4 or 5 models, any way the one i got sent was for KDL-55HX820.
                              Physically these boards are identical, everything on the board is the same. I havent put this board into the TV yet, but am I right in saying all i would have to do is copy the Epprom from my faulty board and transfere it on to the new board, or is there still something else that may stop this working....
                              01-27-2021, 05:49 PM
