Panasonic plasma th-42px600u
  • cb007cb
    • Jan 2014
    • 51
    • usa
    TV powers on fans work green light on SC and SS board all boards look good
    as for caps etc. Now for the clues,
    1 20 red blinks when off no such number on panasonic chart!
    2 Screen is grey/white like its lit but no sound or picture.
    3 Small red light bottom right corner near where antenna goes in.
    4 Panasonic repair manual led me to D board which i replaced with no luck!
    Hope tom66 will be able to help me.............many thanks........CB
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Panasonic plasma th-42px600u
    Ah yes. I remember this one. After much trouble shooting and trial and error it turned out to be a main board issue. Many many caps with over threshold esr. Replace it. It's cheap enough I believe. You can use a th-42px60u as well but will lose front input jack connectivity but is a much more common board.
    • cb007cb
      • Jan 2014
      • 51
      • usa
      Thanks for reply i thought the D board was the main board?replaced already!
        D board hooks onto the main board (DG) which hooks onto the analog input board (H), IIRC.
        • cb007cb
          • Jan 2014
          • 51
          • usa
          So i am replacing the DG board? Thanks!
          • freakaftr8
            • Oct 2012
            • 3743
            It was so simple back then. Lol
            Yes sorry. I replaced the DG board.
            • cb007cb
              • Jan 2014
              • 51
              • usa
              Thanks very much i will get DG board and if it works i will let you know
              and i will be a very happy camper!!! Thanks..............CHRIS.
              • cb007cb
                • Jan 2014
                • 51
                • usa
                Replaced DG board still got 20 blinks but picture now black in middle with 2 thick white vertical bars each end of tv?
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Put back in your original dg board. Are the lines still there?
                  Before you try that though hit the format button on the remote and see if the lines go away.
                  Something may not be supplying these boards with the proper voltage possibly. Or your dg you just received may also be faulty.
                  • cb007cb
                    • Jan 2014
                    • 51
                    • usa
                    The remote does not have a FORMAT button on it its the original remote says tv guide at the bottom?When i turn it on with the remote their are no lights on it clicks relays twice then the white lines come on if i use the remote it goes on and off with no lights.If i use the tv power button when it shuts off the 20 red blinks go on?Any clue?thanks.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      yes this is the same exact problem that I had it has something to do with the flaky Eeprom. I tried software updates did not help I replace the mainboard problem was solved for me I don't understand where the white bars are coming from except maybe the TV is set in letter box mod but you can't see anything on the screen. Mine did the same thing with the remote also where I had absolutely no picture at all and if I turn it off by the remote there was no flashes but if I turn it off by the TV there were 20 flashes. I tried every board I could possibly think of because I had a spare parts TV that had a crack screen and when I swapped out the mainboard problem was solved. I can't say for certain that you're bored is defective that you just purchased or not but what I would do if I were you would be to put in your original DG board and see if the white bars are still present. just to confirm you have no swapped out all boards except for the analog tuner board that In the shield right?
                      • cb007cb
                        • Jan 2014
                        • 51
                        • usa
                        Glad you had the same problem and thanks for your help.The d board and dg have been replaced but i never replaced the analog tuner in the shield!I will swap back the dg board and see what happens and let you know.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          not sure if you have this document
                          • cb007cb
                            • Jan 2014
                            • 51
                            • usa
                            I have the service manual which is similar to yours i think yours is more colorful!
                            THANKS!
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              10 blinks is saying tuner as well in that manual i posted.
                              • cb007cb
                                • Jan 2014
                                • 51
                                • usa
                                its not 10 blinks its 20 blinks!
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  You got a dg, d, dt, and pa board right? try hitting the D board with heat well the TV is on and see what happens?
                                  • cb007cb
                                    • Jan 2014
                                    • 51
                                    • usa
                                    heat did nothing.nothing with remote.Will now put old dg board back and see what happens!Also is their supposed to be a red light on the dt board bottom right in a small black plastic square?thanks
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Yes red led is normal. How about heating dg while off. Then power up while board is hot
                                      • cb007cb
                                        • Jan 2014
                                        • 51
                                        • usa
                                        ok will try that now....be back in a bit............thanks
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
