insignia ns-32lcd
  • monopoly96
    • Nov 2013
    • 16
    insignia ns-32lcd
    Hi I have an insignia ns-32lcd with no picture or sound when it is plugged in only the red standby led blinks and will not change even with the power button pressed. Power supply voltages are correct when board c is disconnected (pics below) but when it is connected the 24v output fluctuates from 24 down to about 9 and back up again in sync with the standby light. I know the power supply is good since I know a friend with the same tv and I tested with that, still the same problem. Any ideas on how to fix this?
  • monopoly96
    • Nov 2013
    • 16
    Re: insignia ns-32lcd
    thought pictures were attached but forgot to hit upload, here they are
    • monopoly96
      • Nov 2013
      • 16
      anyone have an idea on what could be wrong?
      • dcapper
        • Dec 2013
        • 496
        Wish I could help you. I have the same tv with a blown 18N50. Mine is definitely the psu but yours seem to be more in depth of a trouble.
        • dcapper
          • Dec 2013
          • 496
          Actually you could have a psu problem. You have power hooked up with no draw and the voltages are correct. But once a draw is on it drops. You could have a bad cap not holding the charge. Look at your caps. I would replace all of them. My 18N50 is completely shorted and it blows the fuse so I have to replace it.
          • monopoly96
            • Nov 2013
            • 16
            Thanks for your response! Thats what I thought at first and replaced all the caps, but the problem was still there so i borrowed a friend's tv's psu and it did the same thing so i'm thinking the main board could have a problem with how its activating the primary on the psu since without it plugged in the 24v pins are 0 and with it they go from 24 down to 9 whenever the standby light blinks and back up to 24. Any other ideas would be much appreciated since i've got no clue what could be bad specifically.
              OK, that large black main filter cap, measure the voltage RIGHT AT THE TWO LEGS of the cap, it should go up from 170V to around 370~400VDC when power switch is activated (PS_ON signal from the main board will turn on the PFC Voltage booster and the 24vdc power supply).
              • monopoly96
                • Nov 2013
                • 16
                Alright the large filter cap reads 290v before and after the on button is pressed and fluctuates down to about 275v in sync with the 24v fluctuations. It seems like it ignores the power button completely. Without any board plugged into the psu the large cap reads 170v.
                  Sounds like you have a PFC circuit fault, the most likely suspect would be the 450V capacitor.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    so your freinds psu is working in his set ok? but when you put his working psu into your set it plays up just like your own psu does.
                    • monopoly96
                      • Nov 2013
                      • 16
                      In response to vinceroger yes, so i'm pretty sure it isn't the psu being the problem especially since it works like its supposed to (to my knowledge) without the main board plugged in. Since the on button and remote seem to do nothing could it be a problem with the main board?
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • Yanleb
                        UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                        by Yanleb
                        My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                        Disconnecting the main board from the power supply makes the backlight come ON.
                        I did disconnect the panel cables and the WIFI modules, the board is still dead.
                        I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                        Thanks.
                        11-18-2024, 12:34 AM
                      • reessi
                        JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                        by reessi
                        I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                        You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                        Years ago it had some bulging caps...
                        04-26-2021, 11:42 AM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
