Philips 42PFL9603 strange behaviour
  • PowerAmpFreak
    • 982
    • Sweden
    This set, a Philips 42PFL9603H acts very strange.
    First turn on, it does not react to remote or input signals. Backlight comes on, PSU voltages are fine.
    I have to turn it off and back on to have it operational.
    Sometimes it requires a third off and back on to have the sound up and running.
    It has the latest firmware, according to Philips download site.
    This obviously looks as a mainboard problem, but when it's on, it runs perfect.
    Phew....
  • PowerAmpFreak
    • 982
    • Sweden
    Re: Philips 42PFL9603 strange behaviour
    It appears if Input source are selected any of the HDMI inputs, and there is no signal applied to it, the set will sort of "crash" during bootup. It retries to boot, set starts up, and goes through the loop again.
    Set has to be pulled from mains to exit this, and after one or two times it can operate correctly.
      Check all voltage regulators, particularly any that supply the main processor or HDMI input chip, if there is one.
      • PowerAmpFreak
        • 982
        • Sweden
        This ended up changing the mainboard. First one I've recieved brand new was bad. It went into protection right away, complained about internal I2C error.
        Got a second one, which did the trick and set is back to operation.
        • freakaftr8
          • Oct 2012
          • 3743
          Yes there are two 6 pin regulators that like to fail on the philips magnavox mainboards.
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            @freakafter8 where might these regulators reside? I have 3 Phillips TVs with main board troubles. One acts a lot like the op described. Are they actual voltage regs?
            Liberating magic smoke one part at a time
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
            • Federause
              HP 250 G7 - Battery Issue (Lid behaviour)
              by Federause
              I have an HP 250 G7 for assistance. I've changed the battery (the old was dead) with a not-original.
              It has a particular behaviour that I've never seen:
              With the lid open, the voltage is present on the relative pins. Upon a time I close the lid, after 5-10 sec. the voltage drops down to 0. If I re-open the lid, the battery keeps stuck in this situation. I have to connect the power supply to "resurrect" the battery. In this way, I can power on the laptop without any problem and also use it without the power cord. If i shutdown the laptop, keeps it with the...
              09-08-2024, 03:34 AM
            • double_DD
              Philips curling iron - is this a common AC cable?
              by double_DD
              Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
              As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
              Not sure if this is something Philips proprietary, or a standard, but the cable plug...
              08-18-2025, 10:04 AM
            • janos6662000
              Philips 47PFS7509/12 LCD TV problem
              by janos6662000
              Hi
              I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
              When i applied cable signal to check image, i had normal picture, but TV was restarting.
              I downloaded original firmware and applied the update, but the problem remained.
              From a colleague i received a "factory package software" which is a lot bigger.
              I made another firmware update, but still did not solve the problem.
              Somewhere on the way the error got worse, because at the moment the...
              08-12-2025, 12:54 PM
            • aidanmo
              Philips 43PUS7506/12 - Loud blown out sound
              by aidanmo
              I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
              I thought maybe the speakers got damaged, so I replaced them - no dice.
              • Using the internal speakers, it always happens.
              • Using the headphone jack, it never happens.
              • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
              02-28-2025, 03:13 PM
