Samsung UE32F4510 Red led blinking
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4325
    • Italy - Milan
    #41
    you did not well things, if backlight comes on on the last test then you have to check also main board psb outputs, if them ok then is highly difficult that jumpering A5v to power on did not turned outputs on.. THE QUESTION: have you ever tested a tv power supply?!
    • electrocuted
      • Aug 2023
      • 39
      • alban
      #42
      Good news!!! the tv works with shorted DS on mosfet. I guess the noise is not harmful... what happens if I make the short permanent?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4325
        • Italy - Milan
        #43
        So it's bad circuitry prior the mosfet, no you cannot make the short forever
        • electrocuted
          • Aug 2023
          • 39
          • alban
          #44
          ok thanks, I'll look into that
          • electrocuted
            • Aug 2023
            • 39
            • alban
            #45
            Well, congratulations to both of you, it was a cold soldering on the negative pin of CM851. I guess this was "informing" power supply that the led inverter was operational and it would not turn on. Thanks again for the help!
              • 12179
              • U.S.
              #46
              • electrocuted
                • Aug 2023
                • 39
                • alban
                #47
                This is the spot that was faulty!
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #48
                  Glad you managed to fix the tv in post 18 i mentioned might be a bad solder joints some are certainly hard too spot expecially when were diagnosing over pictures
                  • electrocuted
                    • Aug 2023
                    • 39
                    • alban
                    #49
                    Thank you too, I just could not believe that it was something simple as that!
                      • 12179
                      • U.S.
                      #50
                      Yep, the one time I didn't give the solder joint speech early, that's why the simple things should not be overlooked. Would have been a shame to tear down to backlights and or buy a new powerboard, just for a bad solder joint that's fixed with a quick check and a little solder.
                      • electrocuted
                        • Aug 2023
                        • 39
                        • alban
                        #51
                        I hear you, next time I will surely know where to start from...
                          09-07-2024, 05:50 AM
                        • cheeky2
                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                          by cheeky2
                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                          06-15-2025, 05:12 AM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                        • MtnManMike
                          Samsung UN75J6300AFXZA LCD TV Power Supply Troubleshooting
                          by MtnManMike
                          I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
                          When I plug the TV in, the screen flashes on and off and...
                          07-23-2022, 06:43 PM
