you did not well things, if backlight comes on on the last test then you have to check also main board psb outputs, if them ok then is highly difficult that jumpering A5v to power on did not turned outputs on.. THE QUESTION: have you ever tested a tv power supply?!
Samsung UE32F4510 Red led blinking
Good news!!! the tv works with shorted DS on mosfet. I guess the noise is not harmful...what happens if I make the short permanent?
Well, congratulations to both of you, it was a cold soldering on the negative pin of CM851. I guess this was "informing" power supply that the led inverter was operational and it would not turn on. Thanks again for the help!Comment
Glad you managed to fix the tv in post 18 i mentioned might be a bad solder joints some are certainly hard too spot expecially when were diagnosing over picturesComment
Yep, the one time I didn't give the solder joint speech early, that's why the simple things should not be overlooked. Would have been a shame to tear down to backlights and or buy a new powerboard, just for a bad solder joint that's fixed with a quick check and a little solder.Last edited by nomoresonys; 02-15-2024, 06:21 AM.Comment
Assuming...7 Photos -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by alltvrepairsHi,
I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
Any one met this problem in the past?...Yesterday, 07:34 AM - Loading...
