Sony Bravia KDL55EX500 Service Manual
  • max1636
    • Dec 2013
    • 80
    I have a Bravia KDL-55EX500 which flashes 6 times, briefly shows the Sony logo, makes a buzzing sound (From an actual buzz speaker I believe), shuts off, then repeats one more time, then flashes 6 times.
    Once I have more information I will post on here but for now I was just after a service manual to find out what the 6 flashes mean. From what I've read so far I believe it's an inverter board error.
  • R_J
    • Jun 2012
    • 9624
    Re: Sony Bravia KDL55EX500 Service Manual
    6 blinks = Backlight error
      Service and training manuals.
      • max1636
        • Dec 2013
        • 80
        Thanks guys. I ordered a new inverter board but I'm worried it won't fix the problem. I measured all the transformers with an ohm meter and usually the way I tell will be that one or two will give me different readings than others but every transformer was the same. I also measured all the test points for the over-current/protection circuits and got nothing. Even more confusing is that every transformer is outputting the same voltage (175v I believe). But I guess I won't know till I try it.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          I may be wrong (frequently am) but ccfls usually require a start voltage
          1500 to 2000 vAC there are not many multimeters that can cope with that
          and there is always a chance of flash over - generally I would say never try to test the output of an inverter transformer without special equipment.
          You can test the secondary winding resistances and compare those.
          Edit see you have done that.
            Please read the training manual, the board connected to the lamps is BALANCER board, the power supply-inverter board combo is the other board.
            Similar setup to SAMSUNG.
            http://www.youtube.com/watch?v=oE6K4...ature=youtu.be
            • max1636
              • Dec 2013
              • 80
              This is exact video I used to test as I mentioned none of the points indicated over-current or a bad tube. But the problem is the TV is only on for about a second. So it's difficult to be sure maybe it just goes over as it turns off. Some of them have small differences but too minor to say that particular tube/transformer is bad.
              • max1636
                • Dec 2013
                • 80
                Anybody got any other suggestions to test the inverter board? I have already ordered a new one but it will be a few days till it arrives.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I'm in the same boat with a 46EX400 with 2x blink error code.
                  Replaced two main board two power boards, even a T-con board and now the only thing left are the tubes or balancer board.
                  I have checked the transformers myself and didn't find anything out of ordinary.
                  I think that I will take apart the screen to see the tubes.
                  For me the 2x blink means bad power supply, but if I force the power supply to turn on I have all the voltages and the backlight it turns on too. So it's very confusing. With another mainboard the TV will work for a while, but then it's back to 2x error code.
                  • mack505
                    • Jul 2011
                    • 44
                    • US
                    Did you ever resolve this? I am having the same issue.
                    Saved - Element 24" LCD TV, Spectre x22wg-Gamer, LG Plasma DU-42PX12XC, Pioneer Plasma PDP-42A3HD, SONY KDL-55EX501
                    • mack505
                      • Jul 2011
                      • 44
                      • US
                      Replacing D1 board resolved this for me.
                      • kramer826
                        Sony KD-55X8500F service manual BL-on signal
                        by kramer826
                        Hello , I am looking for a service manual or schematic information to find out where to measure BL-on signal backlight on signal from the mainboard.
                        I have a tv which works fine and a spare main board that Ii am trying to fault find that is not turning the backlight on,6 flashes.
                        The backlights work ok with other main board.
                        Thankyou for any information
                        07-14-2023, 03:50 AM
                      • JUCaESAl
                        Sony bravia KD-65AF9
                        by JUCaESAl
                        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                        10-20-2025, 04:03 AM
                        LCD LED TV Service Menu Codes
                        TCL LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        10-31-2024, 03:58 AM
                      • PopsCaps
                        Sony Bravia KDL-40V2500 that will not power on
                        by PopsCaps
                        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                        I do not hear any sound and I cannot see any backlight.
                        I have tried disconnecting every cable on each board one at a time to see if anything changes.
                        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                        03-25-2025, 11:23 AM
                      • alegatorul
                        sony bravia kdl-43w756c, no power, no sound
                        by alegatorul
                        the charger brick has 19,2-19,3 vcc
                        changed the inverter board same result.
                        where should i start?
                        cheers
                        11-15-2025, 10:00 AM
