LG 42LK450 Which Wire to Unplug Help
  • truep
    • Aug 2010
    • 373
    Re: LG 42LK450 Which Wire to Unplug Help
    First set the multimeter to 24V or higher. Then ground the black probe to a screw hole on the chassis. Check the 5 V pins first, and then the 3.3V on the connector. Sometimes you need to press really hard to get contact or use a safety pin to get into the connector tho make contact.
    • mbosma
      • Dec 2013
      • 12
      We'll, I didn't get a reading again. Then pulled a dumb move and tried to check the voltage on the fuse, while plugged in. Popped the gfi in the garage, and blew the fuse. I'm in over my head and will bring it in before I do irreversible damage. Thanks for your assistance so far. I hate giving up without at least trying.
      • newtothis
        • Mar 2013
        • 1556
        • england
        O.K lets start from scratch here... Do not worry about the fuse, We have all done it at some point... If the fuse blew its a good thing as its stopped any major damage occurring.
        Take a pic of your multimeter and upload it.
        We will talk you through step by step of how to exactly test the outputs... If you are unsure then DO ask us!
        I will and hopefully anybody else following this thread will take any pics you upload and highlight what you have to test as well as highlighting what your DMM has to be set to.
        Right... you had a standby light... this means you had a 5v output... without this the standby light would not come on. The PSU (Power Supply Unit) will send 5v to the main board at all times... This is so the main board has the voltage ready for the standby function... when you press the power button the main board picks this voltage up and sends ~>2.5v to the PSU PS ON/OFF Pin telling it to switch on.
        Do you understand this so far? If not then shout up any questions you have
        Once the PSU has this signal the remaining voltages will become present... if any fault becomes present within ~ 3 seconds a signal is sent to the PSU to switch off.
        So we start to troubleshoot....
        Get the pic of your DMM and we shall start... ready?
        • wnlewis
          New wire for my RDE3340 Whirlpool electric range
          by wnlewis
          OK. I got the rocker switch figured out thanks to the good advice on this forum.
          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
          This is a Whirlpool RDE3340 electric range.
          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
          Where may I find parts...
          01-08-2025, 11:21 PM
        • emeskay
          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
          by emeskay
          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
          08-06-2024, 07:13 AM
        • technicalspecialist
          Vintage fan repair, copper wire question
          by technicalspecialist
          I currently have a customer's vintage fan on the work bench to repair.
          It uses an induction motor with 4 poles. One of the poles is open.
          I couldn't find the break so i cut off the original wire.
          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
          The enamelled copper...
          03-16-2023, 12:54 PM
          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
          12-16-2023, 08:39 PM
        • kalemaroni
          Dell DC Brown wire
          by kalemaroni
          There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
          08-26-2025, 10:10 AM
