VIORE 32" - Power board problem?
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Destroyer-Br
    [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
    by Destroyer-Br
    I'm working on an Acer Nitro 5 unit with the following specs:
    • Motherboard: LA-J871P Rev: 1B
    • Model: Acer AN515-55-59MT
    • S/N: NHQ7JAL00403906A973400
    • SNID: 03902728734
    Initial Issue
    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
    04-17-2025, 08:18 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
    After all of...
    07-13-2024, 08:14 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
