Back light problem
    Re: Back light problem
    I think 3kV will be fine there, for 32" panel voltage unlikely to exceed 1.5kV starting, 900V operational.
    • snipersquad100
      • Nov 2013
      • 330
      • uk
      #42
      thanks tom.
      just goto wait and see if it fixes it.
      • snipersquad100
        • Nov 2013
        • 330
        • uk
        #43
        Problem solved, It was those two caps, and they were 3kv I took out as well.
        Many thanks to all that helped.
        Merry Christmas and a happy new year to all on the forum.
        • ron77
          • Dec 2012
          • 63
          • united kingdom
          #44
          Just repaired an Alba lcd32880hdf. Was puzzled until I read this thread. Replaced c230/c231 3kv, television worked perfectly. Checked for dry joints, seemed ok. Couldn't fault old capacitors in any way, they read same as replacements. Got spare caps off Darfon backlight board,v144. 16 on that board. I would have bought replacement board, hopefully, the p.s.u. board. Thanks vinceroger69.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #45
            glad some of my input helped you sort the set out and another set saved from the landfill too.
              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
              I am comparing them to a brand new one that I installed
              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
              I going to let it run for several days before I remount back on the wall next to the...
              09-05-2024, 06:48 PM
            • boyebaran
              hisense 65k560 back light problem
              by boyebaran
              hi to all
              tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
              in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
              please advise me tnx
              05-20-2025, 07:11 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • multimesut
              Dell 2007FPB Yellow Light Problem
              by multimesut
              Hello friends,
              A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
              11-13-2024, 07:00 AM
            • koby058
              vostro comes up with back light but no picture
              by koby058
              Hi people!!
              The owner said it showed bad picture once in a while (attached)
              I see that there is back light but no picture.
              I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
              Also attached schematic and BDV
              LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
              07-13-2025, 01:03 PM
