Westinghouse SK-32H540S
  • CraigR
    • Dec 2013
    • 965
    HI, since people here are stumped on my Haier question I will ask about my Westinghouse SK-32H540S. I received this tv dead as in no power light or sound or anything. The person before me attempted a fix and seen the center transformer on the board was burnt and so was the board so that was replaced. So far I have pulled out the 3 big transformers and compared readings to each other and they seem very close. I also pulled the electrolytic capacitors out and checked them with my Atlas ESR70 and all passed (none looked bulged either) I pulled out the mosfets and checked those also and were ok except for the 2 I have circled in the pic which looks to have diodes as part of one leg and I'm uncertain on how to check them. I also tested the large resistors and diodes on top and seem ok. Next I looked at the solder connections under lighted magnification and touched up anything that looked remotely like something. So after all that I'm stuck.
  • addytzu123
    • Mar 2013
    • 54
    • ROMANIA
    Re: Westinghouse SK-32H540S
    Just throwing some questions here
    All fuses are ok?
    Does voltage reaches the rectifier bridge/main filter caps?
    Is voltage present at the 5 V standby driver IC?
    Any standby voltage output?
    Does the maind board sends the PS_On ?
    In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
    • CraigR
      • Dec 2013
      • 965
      Sorry forgot to mention Yes, power through the fuse and on the low side I have all the correct voltages coming out as printed next to the connector 5v 12v etc...
      • addytzu123
        • Mar 2013
        • 54
        • ROMANIA
        Well, if all voltages are correct (5V, 5Vs and 12V), then regardless of any problem on the inverter side, you should have some activity on the LED (standby light, blinking).
        Is there any voltage on the BL_On pin ?
        In this case verify also the voltages on the main board regulators.
        • CraigR
          • Dec 2013
          • 965
          Might be on to something, no voltage at BL_ON pin. Not sure how to check voltage on mainboard regulators.
          • addytzu123
            • Mar 2013
            • 54
            • ROMANIA
            Well, best if you see it yourself (than a long description)
            Search Youtube for main board voltage regulator test, or:
            http://www.youtube.com/watch?v=cNFzBJELFoU
            • CraigR
              • Dec 2013
              • 965
              Do I even need to check the main board now that there is no BL_ON voltage?
              • addytzu123
                • Mar 2013
                • 54
                • ROMANIA
                BL_on IS coming from the main board ! (it is the Backlight On command/voltage, so the inverter can start)!
                • CraigR
                  • Dec 2013
                  • 965
                  Ok will watch video and get back after testing. Here also is a pic of the main board.
                  • addytzu123
                    • Mar 2013
                    • 54
                    • ROMANIA
                    Read similar threads:
                    https://www.badcaps.net/forum/showthread.php?t=21240
                    https://www.badcaps.net/forum/showthread.php?t=22440
                    • CraigR
                      • Dec 2013
                      • 965
                      Ok, I think I did this correct. Here is a pic with the voltages and where I got them. Also read those threads before posting the first time.
                      • addytzu123
                        • Mar 2013
                        • 54
                        • ROMANIA
                        This is another story :P
                        IC206 is ok, 5V on it's output as it should;
                        Q201 is probably a transistor, not a voltage reg;
                        What voltage is on middle pin IC202 (should be 3,3V)?
                        Deafinetly a problem on IC712 (what is the marking on it?) - has input, but no output!!
                        Question mark on IC711, but i see no input voltage on pin 3 (what is the marking on it?)?
                        • CraigR
                          • Dec 2013
                          • 965
                          3.28v on the middle leg.
                          and on IC712 I double checked volt and what I have is correct. On the chip is J355 and under it is 1117-33
                          The marking on IC711 is K051 and under that is 1117-18
                          • addytzu123
                            • Mar 2013
                            • 54
                            • ROMANIA
                            Right, 3,28V it is correct!
                            IC712 is also a 3.3V regulator, and 99% faulty!
                            IC711 is a 1.8V regulator, and I belive that it's taking the 3.3V from IC712 as input (but since IC711 has a problem the voltage never reaches the input) so it might be ok.
                            Next step would be to replace the IC7111, 3.3V regulator and post the results !
                            All the best
                            • addytzu123
                              • Mar 2013
                              • 54
                              • ROMANIA
                              Correction - replace IC712
                              • CraigR
                                • Dec 2013
                                • 965
                                Thank you so much for the help. Any suggestion where to get one? Thanks again!
                                • addytzu123
                                  • Mar 2013
                                  • 54
                                  • ROMANIA
                                  http://www.digikey.com/product-searc...=0&pageSize=25
                                  http://ro.mouser.com/ProductDetail/S...WdNxB93SNXjw2a
                                  Or try from salvage boards, they are quite common!
                                  • CraigR
                                    • Dec 2013
                                    • 965
                                    Well got the part from mouser in your link and put it in and still dead.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Ok - Can you test test the new VR to see what voltage it gives?
                                      Retest the others as well.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        did the voltages on the regulator alter with the new part or is it the same as before?
                                        • Dvsr
                                          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                          by Dvsr
                                          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                          After replacing the caps I started testing out the speaker. It seemed...
                                          09-10-2025, 10:20 AM
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • jordanaudio1
                                          Samsung TV UN60KU6270F power supply
                                          by jordanaudio1
                                          Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
                                          My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
                                          07-07-2025, 07:38 PM
                                        • KYBOSH
                                          Wine and Beverage Cooler Control Board Repair Attempt
                                          by KYBOSH
                                          Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
                                          Model number AWBC242GGFD
                                          Previous owner states that it needs a new motor.
                                          When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
                                          I pulled out the main control board to give a look.
                                          Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
                                          07-18-2024, 11:52 PM
                                        • Nikolai Danylchyk
                                          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                          by Nikolai Danylchyk
                                          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                          Thanks in advance!...
                                          05-08-2025, 06:18 AM
