Westinghouse SK-32H540S "2 seconds to black" Darfon
  • high-tech
    • Sep 2010
    • 197
    I found a transformer with shorted secondary and replaced with new, and the TV still shuts the backlight off after a couple seconds and it trys a second time but still no good. I checked the N channel mosfets feeding the primary side of the inverter transformers and they are good. I don't have a schematic for this board and wish I could find one...
    Im hoping somebody here knows this problem inside out
    im getting the necessary voltages on the ps_on and bl_on pins on the power supply board connector
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Westinghouse SK-32H540S "2 seconds to black" Darfon
    I'm used to seeing the secondary transformer pins go open circuit, not shorted.
    See
    http://www.lcdparts.net/TransformerD...ProductID=2775
    Measure the resistance between S1-S2 and S3-S4. Both readings should be within 3% of each other on all your transformers.
    --- begin sig file ---
    --- end sig file ---
      Was one of the transformer burnt out so bad that it has big hole on the board?
      How are those small ballast blue caps by the outputs of the transformer? Any of them has any resistance reading, specially the ones by the new transformer you put that has burnt hole on the board.
      • high-tech
        • Sep 2010
        • 197
        See
        Im sorry, the Xformer did open up and the other 2 xformers all measure right at 1.8k on Secondary pins, thanks for your feedback, I'm not sure what to do next. Im not familiar with the control circuit for this inverter.
        • high-tech
          • Sep 2010
          • 197
          The board was burnt bad enough to eventually cause the secondary high voltage to leak so I decided to carve the hole out a little bigger to remove the semiconductive material left behind by the burnt xformer.
          All the blue caps check ok, they all read open on the highest resistance scale on my meter.
            Well, you did that correctly to carve out the carbonized section of the board. The possibility still can be the driving circuits or can be bad lamps.
            • high-tech
              • Sep 2010
              • 197
              I used a set of test lamps and they all light up for 2 seconds and go off again so my bulbs are ok im pretty sure.
                You are in the same boat as this one:
                https://www.badcaps.net/forum/showthread.php?t=21240
                • high-tech
                  • Sep 2010
                  • 197
                  Just for giggles I measured the voltage at the main filter caps after the rectifier and I got 161 volts dc with the set turned off. While the inverter is on I got 148 volts, a 13 volt drop.
                  I think it should be up around 167 vdc off and im not really sure what the normal load is
                  • learnmore
                    Help choosing replacement transformer for Levoit 600S SMPS
                    by learnmore
                    Hello Community,
                    I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                    Peace
                    LM...
                    11-04-2025, 09:35 AM
                  • ohren
                    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                    by ohren
                    Hello!
                    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                    Measured voltages with no load:
                    After rectifier diodes
                    12V: 6.17 V
                    5V: 5.67 V
                    Secondary transformer pins AC measurement (really don't know if this says anything)
                    12V: 2-2.5 V
                    5V: 1.04 V
                    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                    03-18-2023, 10:33 AM
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                  • twonk9098
                    Lenovo Legion 5 high fan spin turns off after 34 seconds
                    by twonk9098
                    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                    I have tried a few new bios but exactly...
                    07-14-2024, 11:19 AM
                  • mikey5791
                    Is it possible for transformer substitution?
                    by mikey5791
                    Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                    Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                    My questions are
                    1. How do i test to see if the transformer is in good working condition?
                    2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                    Hope you guys understand what i was asking. My intention is...
                    11-03-2022, 02:11 AM
