Polaroid FLM-3232: Help Identify Diodes in PFC Cct
  • martyparish
    • Dec 2012
    • 313
    I found a cracked diode and there are no labels that I can see. There's a yellow band and a black band, however almost every glass diode on the board looks like that, so I surmise that it's not a identification code???
    I am attaching an image of the board and an image of the "Typical Application Circuit". I'm not a tech, so I am having a hard time comparing the circuits and figuring out the proper diodes to install.
    Can you guys have a look please?
    Thanks!
    ps. this old thread has gotten me to this point https://www.badcaps.net/forum/showth...t=27692&page=2
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Polaroid FLM-3232: Help Identify Diodes in PFC Cct
    Can you give me the model number off the board please
    • martyparish
      • Dec 2012
      • 313
      Part Number:
      846-240-H3CZZS
      Board Number(s):
      S0804-0901
      http://www.shopjimmy.com/proview-846...upply-unit.htm
      Thanks for the help!
      • martyparish
        • Dec 2012
        • 313
        I'll give this one bump, in hopes that someone knowledgeable can have a look. Thanks
        • xyloeye
          • May 2011
          • 20
          I sent you a pm (because the thread was old) a couple of weeks ago about the same problem you're having. I didn't see this thread, only the original. Anyway, I have the same psu with 24v present until I plug in the main board. Then the inverter voltage goes to .09v and the main board supply to 16v. I thought the main was fried so ordered a replacement from Shopjimmy. The new board didn't help. Now I'm thinking the psu is getting swamped by the load or maybe too much ripple. Haven't had a chance to get back to it. Did you ever figure anything out?
          As far as the diodes, I'm pretty sure the yellow band indicates that they're zeners. I don't think you can tell the voltage from the markings though. These come in 2.4 to 75v rating!
          • Dvsr
            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
            by Dvsr
            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
            After replacing the caps I started testing out the speaker. It seemed...
            09-10-2025, 10:20 AM
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • magneh
            Motorbike PCB - burned Diodes ( PJ78) - help to identify identical or equivalent
            by magneh
            Hello everyone
            Got a motorbike PCB that had 3 burned diodes.
            The smaller ones have the marking PJ78 GS1M
            And one larger one PJ78 GEX
            Can someone help me identify them so I can be able to replace with same or equivalent?
            Photos attached
            Apreciate !
            Thank you...
            05-19-2025, 07:38 AM
          • thesame
            DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
            by thesame
            Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
            The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
            02-27-2024, 04:31 AM
          • silver60618
            Lenovo Legion 7 - Help Identify IC
            by silver60618
            Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
            I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
            Any help would be appreciated...
            07-02-2025, 12:16 PM
