Lcd37tv016hd
  • snipersquad100
    • Nov 2013
    • 330
    Lcd37tv016hd
    ok Thank you vince.
    I got this Bush 37inch LCD, It would work for about 5mins then the picture would go fuzzy "see Pic 2" and about 2 mins later the set would turn off. I've had the air duster out to blow a few cobwebs now im just getting a gray screen. "pic3"
    I've checked voltage on the power supply 23.8v, 11.7v, 5.2v and 5vSB are all there.
    Can anyone point me where to investigate next.
    Thanks.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Lcd37tv016hd
    are you still getting sound ok
    • snipersquad100
      • Nov 2013
      • 330
      Re: Lcd37tv016hd
      Yes, Lucky enough when I first switched on the set to get the gray screen for the first time the hdmi channel was still tuned in and I could here the ps3. I since pressed a channel button now I cant here anything as I don't know what channel is currently tuned in, but it deffo worked when the hdmi channel was on.
        Re: Lcd37tv016hd
        Check for 12V or 5V at both ends of tcon fuse.
        • snipersquad100
          • Nov 2013
          • 330
          Re: Lcd37tv016hd
          Nope no voltage on either side. continuity on f1 is ok thou.
          I take it there no power coming from the main board.?
            Re: Lcd37tv016hd
            Sounds like it; check LVDS, check the silly parallel port thingamajig on main board is seated properly too (that got me good for some time on these!)
            • snipersquad100
              • Nov 2013
              • 330
              Re: Lcd37tv016hd
              is the ldvs the plug that gos to the t-con board, if so im only reading a volt or so on some wires, parell plug at rear seams snug.
                Re: Lcd37tv016hd
                Yeah that's the LVDS.
                • snipersquad100
                  • Nov 2013
                  • 330
                  Re: Lcd37tv016hd
                  Have you got a schematic on this main board ?
                    Re: Lcd37tv016hd
                    No, I've not found one yet.
                    • snipersquad100
                      • Nov 2013
                      • 330
                      Re: Lcd37tv016hd
                      ok, thanks tom
                      • snipersquad100
                        • Nov 2013
                        • 330
                        Re: Lcd37tv016hd
                        I got the board out, its number is FCBF076072574 Any ideas where I can obtain another one or if anyone got any idea on how to fix this one. This one is not supplying voltage to the t-con board.
                        Do surface mount electrolytic caps bulge when bad?
                        • snipersquad100
                          • Nov 2013
                          • 330
                          Re: Lcd37tv016hd
                          UPDATE
                          I put the LDVS cable in the wrong way. DOOHHHH
                          So im back to my original problem that the tv starts up ok then pic goes funny. but im getting this image now.
                            Re: Lcd37tv016hd
                            Check PSU voltages are steady.
                            • snipersquad100
                              • Nov 2013
                              • 330
                              Re: Lcd37tv016hd
                              Further update. I have found out that the tv only goes faulty after 5 mins on the HDMI input. The Scart, ariel and vga input work ok. Does that mean the HDMI chip needs replacing? or change the main board.
                              • eccerr0r
                                old X58 triple channel board... memtest86 memory speed?
                                by eccerr0r
                                Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                06-28-2025, 09:06 AM
                              • spleenharvester
                                Reverse engineering of 18650 4-channel tester
                                by spleenharvester
                                Hi friends
                                I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                05-04-2025, 02:43 AM
                              • mikey5791
                                Help on car amplifier only one channel works
                                by mikey5791
                                Hi all forum members,
                                Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                08-06-2025, 10:36 PM
                              • dicky96
                                Hitachi V19B01922 Channel Tune problem
                                by dicky96
                                Hi Guys
                                I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                He also has an LG TV, so three screens in the bar
                                I installed three Satlink ST-6503 DVB-T Modulators
                                This model https://www.aliexpress.com/item/32916553905.html
                                These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                02-09-2023, 09:20 AM
                              • dicky96
                                American Audio VLP1500 Distorting on one channel
                                by dicky96
                                Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                Protection and Clip LED are off
                                There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                07-13-2022, 05:25 AM
