Alba lcd32880hdf
  • sordids999
    • May 2013
    • 2152
    Alba lcd32880hdf
    hi guys
    my latest project seems to be stuck with the standby flashing all voltages seem good until after about 10 secs when they drop to virtually zero unless i disable the main board from the psu then the voltages are fine
    main board blown ? or could it be the screen even the backlight does not light up
    thanks
    Re: Alba lcd32880hdf
    When you say "disable the main board" what do you mean? You can wire on the BL ON/OFF to check backlight.
      Good clear pictures of the boards?
      • sordids999
        • May 2013
        • 2152
        sorry tom i mean this main cable going to the main board the psu makes a buzzing noise when i first test the voltages but this stops buzzing and the voltages drop pretty fast i have since got another psu but its still the same
        • sordids999
          • May 2013
          • 2152
          here you go
            These boards are a bit of a bugger because pins # on connector aren't labelled, schematic is here. By tracing grounds you can figure out orientation.
            http://www.tgohome.com/ServiceManual...&Search=Submit
            You'll want to check if the 5V standby is always present or not.
            If it is, check the PS ON/OFF signal: STBY_ON/OFF.
            If that drops out after it tries to turn on, it could be main board at fault.
            • sordids999
              • May 2013
              • 2152
              pin 8 BL_ON/OFF starts at 5v then drops to nothing
              pin 6 STBY_ON/OFF starts at 5v then drops to nothing
                Do you have steady 5V STBY, pin 14? What about 3.3VSTBY on pin 15, 16?
                • sordids999
                  • May 2013
                  • 2152
                  Pin 14 5v does not drop
                  Pin 15 4.9 to 5v does not drop
                  Pin 16 nothing
                    Looks like your main board is bad. To confirm everything else is OK you can run a wire between STBY 5V to STBY ON/OFF and BL ON/OFF with connector removed from main board end. Backlight should come on, all voltages should be steady.
                    • sordids999
                      • May 2013
                      • 2152
                      run a wire from pin 6-8-14 and no backlight coming on
                        Just to make sure check you have 24V at inverter and >3V on blue or yellow wires going to inverter.
                        • sordids999
                          • May 2013
                          • 2152
                          yes 24v at invertor but the blue wire going to the invertor has no voltage
                          • sordids999
                            • May 2013
                            • 2152
                            the orange wire next to the blue has 2.5v
                              Is the orange the last wire in sequence or ...? Last wire should be BL ON/OFF. Tap screen lightly, do you see a white spot?
                              Perhaps DIM need to be connected too, so try connection between BL_ON/OFF and B_DIM (#8 and #10.)
                              • sordids999
                                • May 2013
                                • 2152
                                blue is the last on in sequence
                                and do you mean connect all together 6-8-14-10 ?
                                and no white spot showing when i tap the screen tom
                                  Yeah, when you get it correct there should be >2V on the last blue wire.
                                  • sordids999
                                    • May 2013
                                    • 2152
                                    ok 5v on the last blue wire now
                                      Any backlight? Must also have 24V.
                                      • sordids999
                                        • May 2013
                                        • 2152
                                        nope no backlight tom 5v showing on the blue end cable but 24v not showing on the invertor cables
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
