Sharp LC 46D64U Screen flashes then dies
    Re: Sharp LC 46D64U Screen flashes then dies
    3.3V is fine for a logic signal. Can you see an ERROR output?
    • vinceroger69
      • Mar 2012
      • 6714
      is this your service manual its a free download
      • Bob Kontak
        • Dec 2013
        • 25
        Error output is a green flashing power light on front. Once per second. This is when the tv tries to start, screen flickers and it shuts itself off with a click. It does not always do this. Sometimes it does not click off.
        I believe the every second blink means backlight/inverter issue.
          I meant an error signal from the inverter.
          • Bob Kontak
            • Dec 2013
            • 25
            Oh - as in on the screen - when you go into service mode?
            Have not tried that yet, if so, given the short time screen can be observed.
            • Bob Kontak
              • Dec 2013
              • 25
              Attempting
              Got it. I got sucked into the sponsored links. But, hey, I have Weather Bug now. :-)
              Thank you very much.
              • Bob Kontak
                • Dec 2013
                • 25
                Vince and all.
                Thanks.
                Sorry for the impatience. Let me look over this manual and come back with better questions. If I find the problem I will report.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  never had any issues with using that site at all with adds hope its the correct manual now.
                  • Bob Kontak
                    • Dec 2013
                    • 25
                    No issues with the site. I did not read the sponsored ads close enough and installed some swanky PDF interface file that just loaded some needless stuff which I deleted along with the swanky program.
                    I have the manual in pdf form. Gracias.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      if you can add it as a attachment then if we need to look at it we can and try to help you do it match your tv ok.
                      • Bob Kontak
                        • Dec 2013
                        • 25
                        It's 28MB. Is that too big to upload here?
                        • Bob Kontak
                          • Dec 2013
                          • 25
                          Nope - it won't take it. Too big.
                          Lemmie do some leg work. I am pretty much a leech right now so a little work on my part is warranted.
                          I can post specific screen prints when we start to get the cross hairs on the target.
                          Again, thanks!
                          • bruceleeworldwide
                            • Aug 2016
                            • 4
                            • australia
                            #33
                            no result?
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • EazyBone
                              Sharp LC-65Q620U White Screen
                              by EazyBone
                              Another TV topic!!
                              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                              08-21-2024, 12:56 PM
                            • scubacamper
                              Sharp Aquos LC-70C6400U Half Screen Dark
                              by scubacamper
                              I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                              Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                              when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                              05-03-2025, 12:19 PM
                            • sefoster
                              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                              by sefoster
                              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                              11-20-2022, 09:29 AM
                            • SONY_E-WASTER
                              Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                              by SONY_E-WASTER
                              Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                              The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                              then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                              does...
                              12-26-2021, 05:46 PM
