Lg 42ld550
  • Bigredram87
    • Sep 2013
    • 88
    Re: Lg 42ld550
    The other
    • Bigredram87
      • Sep 2013
      • 88
      Re: Lg 42ld550
      Both removed
      • Bigredram87
        • Sep 2013
        • 88
        Re: Lg 42ld550
        My big question is are the 2 small boards on the top of the tv tcon boards? If not what are they? And if not is the Tcon under the metal shroud
        • Bigredram87
          • Sep 2013
          • 88
          Re: Lg 42ld550
          Im starting to think this main board is also the tcon board? someone please verify. I also have taken pictures of the front and the back of this main board. I have searched it pretty good and I cant find any component labeled F for fuse.
            Re: Lg 42ld550
            I am thinking the main board may be set for a 720p LCD panel. Can you see any model # on it? Also try inputs and menus to see what they look like.
            • Bigredram87
              • Sep 2013
              • 88
              Re: Lg 42ld550
              ok yes 2 numbers
              eax61746403(0)
              LGE2-EBU60852902
              • Bigredram87
                • Sep 2013
                • 88
                Re: Lg 42ld550
                1 more number sorry I dont know hwich one is model. This one is on the little LG coax ebl6072041
                  Re: Lg 42ld550
                  Do you know if the main board has ever been replaced in this model?
                  What does the TV look like if you press MENU on the remote?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Re: Lg 42ld550
                    Well I would never have thought of that. You're like Phillip Marlowe meets Rain Man - and that's a compliment lol.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #30
                      Re: Lg 42ld550
                      Originally posted by mmartell
                      well i would never have thought of that. You're like phillip marlowe meets rain man - and that's a compliment lol.
                      lol!
                      • Bigredram87
                        • Sep 2013
                        • 88
                        Re: Lg 42ld550
                        I do not know about what has been replaced. All I know is when I took it apart the 2 ribbon cables were disconnected. So I don't know what was messed with.
                        This is what it changes to if I press menu
                          Re: Lg 42ld550
                          I would suggest an incorrect main board has been ordered and would try asking the seller if they have the original, or buy a replacement but order using 42LD550.
                          • Bigredram87
                            • Sep 2013
                            • 88
                            Re: Lg 42ld550
                            So I just talked to the guy he said he took it to a tv shop. The charges him 50 to look at it. Than they said it needed a new main board and quoted him another 250 to fix it so he didn't. What do you think should I just buy a main board with the tv model number
                              Re: Lg 42ld550
                              I think Tom is on the right track, sounds like main board is not sync with the T-CON/PANEL. I never seen problem like this before, will be great to know the result.
                              • Bigredram87
                                • Sep 2013
                                • 88
                                Re: Lg 42ld550
                                Ok wanted to update after researching for a few weeks I learned that the main board was correct by contacting lg. I finally found one on eBay and just replaced it. Works perfect! Thank you guys for all the help. If any one wants the old board just for some diagnosing i would be glad to send it to you just pay real shipping cost. Thanks again guys
                                • T-con
                                  • Dec 2013
                                  • 57
                                  • Taiwan
                                  #36
                                  Re: Lg 42ld550
                                  Good for you
                                  • gstein94
                                    • Dec 2013
                                    Re: Lg 42ld550
                                    Does hash move around? If yes its the main, Do you get osd menu. Both of these would prove the tcon and screen ok.
                                      Re: Lg 42ld550
                                      Glad to hear it's working. Maybe internal setting just got corrupted.
