47 in lcd menus don't look right
  • efwiofoi
    • Nov 2013
    • 76
    i have a 47inch baird lcd with a cv109h mainboard and a lg philips LC470WUN panel.
    i've replaced 5 bulging caps in the psu to get the set working. but the menu looks blurred, it's like every other row of pixels is swapped round.
    i think the tv has this effect also but its hard to see.
    i've accessed the service menu, but nothing seems to correct this.
    in the service menu there is ssc adjust, ssc mu on/off, ssc lvds on/off, lcds span (350), lvds step (200). none of these setting seem to make any difference.
    could it be a faulty t con?
    thanks
    Re: 47 in lcd menus don't look right
    The image looks to have this effect too. I would be surprised if the t-con caused this, but a loose LVDS cable could cause this problem. Also check LVDS mode in service menu, etc. If all else fails, the flash chip (incorrectly called EEPROM) could be the cause of this.
    • efwiofoi
      • Nov 2013
      • 76
      ive had the t con out and i think its the wrong one for the panel.
      the panel is actually a LC470WUE, (LC470WUN was also fitted to this model)
      the tcon has been changed, as it has a handwritten sticker on with the tv model no.
      but the tcon says LC470WUN.
      i've found a new one on ebay, which is for an LC470WUE
      however it says LC470WUE (SD)(P1)
      my panel is LC470WUE (SB) (B1)
      close enough?
      • efwiofoi
        • Nov 2013
        • 76
          Are the T-con boards substantially different?
          • newtothis
            • Mar 2013
            • 1556
            • england
            No real difference in these T-cons
            • efwiofoi
              • Nov 2013
              • 76
              i don't know, it seemed like it might be the cause, but i found one on ebay listed as suitable for both panels (from an experienced seller who i think must know), so it comes back to some other problem or a possible faulty tcon. the main board is the right one for the panel as it has the matching sticker on it. the cable looks ok. there's nothing else i can change in the menu. possible faulty flash chip on the main board? is that the big square one with the heat sink on it?
              • newtothis
                • Mar 2013
                • 1556
                • england
                Confirmed that the 2 t-cons will make no difference, I have a WUN panel here fitted with a WUE T-con
                  Could also be bad RAM - a missing bit in the address for it would cause this (odd/even interlacing in video.) Though normally would not line up so well... If so a reflow would be a temporary cure (a reball is really the only permanent fix, most reflows do not last a month.)
                  Strange one, I think I have seen it before on a laptop, but I think that was just bad LVDS.
                  If you have a digital scope or a storage scope you could try sending patterns to the LCD which have slight differences to see what difference it might make in the LVDS signal coming out.
                  • flocko
                    • Nov 2012
                    • 1121
                    Hi with all Lg T-cons the silk screen board number just give you type not part number, on the board in the photo the part number is the one in red and reads 2803A, you need to check the part number for your set, look it up on shopjimmy
                      LCD LED TV Service Menu Codes
                      ALL LCD LED TV SERVICE MENU CODES
                      Service Menu Code with Board Name
                      China Universal Board / Jumper Board Service Menu Code
                      Changhong Ruba Service Menu Code
                      Ecostar LED TV Service Menu Code
                      Orient LED TV Service Menu Code
                      Haier LED TV Service Menu Code
                      TCL LED TV Service Menu Code
                      Samsung LED TV Service Menu Code
                      LG LED TV Service Menu Code
                      Videocon LED TV Service Menu Code
                      Supra LED TV Service Menu Code
                      Toshiba LED TV Service Menu Code
                      Symphony LED TV Service Menu Code
                      Veste/ LED TV Service Menu Code...
                      10-31-2024, 03:58 AM
                    • NolesFan
                      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                      by NolesFan
                      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                      10-24-2024, 06:36 PM
                    • Robby-Gr
                      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                      by Robby-Gr
                      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                      Additional issues:...
                      09-27-2025, 12:02 AM
                    • Retro140
                      Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                      by Retro140
                      So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                      To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                      06-18-2023, 06:13 PM
                    • Ierwin
                      Philips 58PUS7805 Menu working but no/weird picture from video sources
                      by Ierwin
                      I got a 58pus7805 that shows some weird behavior.
                      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                      I managed to install the latest official firmware by holding the control button while plugging...
                      03-10-2024, 12:50 PM
