Hi I have an Insignia LCD tv I picked up for a song. It doesn't work, and the person I bought it from said he went on vacation and when he came back it wasn't working anymore, so he suspects it got hit by a power surge.
When plugged in, the red standby LED comes on. When turned on, the led goes to blue, but no picture appears, and I couldn't get any sound from a device hooked up to it.
I opened it up, and there are no obvious bulging capacitors anywhere. I did find one component that looked a little suspect, marked "NR901" on the PSU board. One of the legs looks a little burnt up.
I found the Service manual for this TV from another thread, and this part is a NTC Thermistor (3ohms 5A +/-20%). I tested it at room temperature and it reads 3ohms, but I didn't try heating it up. I'm not sure if this is the problem or not.
I've also tested all the outputs on the PSU board while powered up, and they all measure within .4v of their markings, i.e.5v, 12v and 24v.
One thing I found is the ON/OFF and PWM pins are 0v whether or not the set is on or off. I took a 3.3k resistor and used it to jumper the 5v to the on/off pin on the PSU while the TV was on. The backlight came on and stayed lit.
So that leads me to suspect that the main board is not working. I'm looking into sourcing a replacement, but before I do that, can anybody suggest anything else I might have overlooked?
Service manual from this thread (post #21): https://www.badcaps.net/forum/showth...S-LCD37&page=2
