Sony KDL-40W4500 panel problem?
  • PowerAmpFreak
    • 982
    • Sweden
    Sony KDL-40W4500 with a picture problem. (see attached pictures)
    Left part of picture having the lines "mirrored" from top to bottom, while the right part is next to problemfree, except for some brighter lines.
    The normal question:
    Is this a panelfailure? Or a T-con, mainboard failure?
    Re: Sony KDL-40W4500 panel problem?
    Tab bonds issue.
    • PowerAmpFreak
      • 982
      • Sweden
      So, a panel failure then? Not possible to repair?
      BTW, it can be good after 15 minutes of operation.
        Not impossible to fix, but the repair isn't always long lasting.
        http://www.youtube.com/watch?v=vCExlSnG4yY
        • Chrissygizmo
          Sony KD-55XG9505 lines on screen problem
          by Chrissygizmo
          Hello again everyone,
          This is my latest mission, to try getting this Sony tv back to normal working order…
          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
          02-19-2025, 11:31 AM
        • Davi.p
          Sony KDL-42W705B panel problem
          by Davi.p
          Hi, this has panel problem for certain (AUO panel), in the troubleshooting process, after pressing ON button i am with set making a short lamp of backlight with status light shortly white then green/yellow repeated, in this situation main board remain powered and also tcon with all their correct output voltages. I cant find in the service manual description of this state, can you brief me ? thanks
          01-26-2023, 07:56 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
        • learnmore
          Samsung UE70TU7020K Which lines to tape on a bad panel
          by learnmore
          Hello Community,
          I'm working on a Samsung UE70TU7020K.
          It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
          I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
          03-15-2024, 03:01 PM
        • Glaval
          Sony OLED XBR-65A8G 4 flashes
          by Glaval
          Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
          01-23-2025, 04:04 PM
