LG 42LG3000 fault
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    • uk
    LG 42LG3000 fault
    Hi folks , picked up this TV with the fault in the picture , sometime i switch it on and it works fine but when i switch it off again i get this fault ...
    any ideas ?
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    • uk
    Re: LG 42LG3000 fault
    screen slowly goes like this ... panel ? tcon ?
    • newtothis
      • Mar 2013
      • 1556
      • england
      Disconnect one of the cables from the panel driver boards to the t con and power up... view results, plug back in and do it to other side... power up and view results
        I have seen this symptom due to bad panels.
        • karlpowell
          badcaps.net
          • Feb 2013
          • 104
          • uk
          ive seen it before on a laptop LCD panel , just seems a bit odd that it works sometimes, ill do as newtothis says and report back later.
            I've seen a bad tab bond cause this, especially intermittent. Is the panel made by ChiMei? Their 26" 720p panels often suffer from this.
            • cosmindaniel
              • Oct 2013
              • 9
              What do you mean like " plug back in and do it to other side....."
              I have the same simptoms, i replace the t-con module(new one), and nothing happend.
              Any ideeas?
              • nomoresonys
                • 12331
                • U.S.
                try flexing the panel, see if display changes.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  If the symptoms are the same as the OP and tcon didn't help you can be pretty sure its a bad panel
