psychedelic effect on screen
  • efwiofoi
    • Nov 2013
    • 76
    i have a baird 42in lcd with a psychedelic effect, the menus and picture are affected.
    is this likely to be the mainboard, t con or screen?
    Re: psychedelic effect on screen
    That looks like Gamma ref voltage problem, the circuit is on the T-CON board (it is under the metal shield locate about top center of the LCD panel. Pictures of the boards?
    • efwiofoi
      • Nov 2013
      • 76
      the main board is a cv109h
      and the panel is a chi mei one, with a v420h1-c15 t-con
      worth a try on the tcon?
        I would actually say it looks like LVDS setting is wrong on main board.
        On these models: service menu is SOURCE 3690. Then go to panel option and try to change settings.
        • efwiofoi
          • Nov 2013
          • 76
          hi tom do i enter that with the remote? there is no 'source', 'input 3690' doesn't seem to do anything?
          • efwiofoi
            • Nov 2013
            • 76
            got it, input 2580, i changed 'ti mode' to on, in the 'function' menu
            that made the menus look normal but still no picture, so i tried 'reset'
            everything is back to normal!
              Good troubleshooting, Tom! I have seen this same picture in Insignia, replacing the AS15 solved the problem, just goes to show that it cannot be 100% for sure, it is good to have people like Tom that have seen problem like this before and able to solve the problem.
                Nice fix. The reason I disagreed with gamma chip fault is the transitions are too sharp. With gamma chip going bad the picture can look similar, but the transitions are completely smooth.
                The menus looked similar to a 24" Bush I did and Source 3690 was for that, obviously this is slightly different.
                  Ah, thanks for the tip on the transitions.
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    I have one doing the same thing at the minute, so i will give this fix a try tomoz
                    :-) fingers crossed!!
                    • shepp
                      • Mar 2012
                      • 377
                      • England
                      Excellent fix.......so far so good! :-)
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
                      • ipatch
                        ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                        by ipatch
                        i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                        08-24-2024, 02:36 PM
