Cello C32109F v2 Sound No Picture
  • anotherdude
    • Feb 2013
    • 488
    So the kids TV just went off with no picture but sound still remained
    looked for anything obvious and googled part numbers but didn't find anything av board wise
    not sure where to go from here just bin it, dead screen or?
    Re: Cello C32109F v2 Sound No Picture
    Screen backlit or not?
    • anotherdude
      • Feb 2013
      • 488
      i've no idea sorry was bought some time ago and never paid that much attention
      googling the power board seems to say it is backlit
        I think Tom is asking if you can see the slight glow on the screen when you look at it in the dark room, if the backlights are working, then the next place to check will be the fuse and the voltahe on the T-CON board. The screen looks like it has integrated T-CON type.
        • anotherdude
          • Feb 2013
          • 488
          ok just turned the lights out and turned it on theres no visible change one thing I did notice is theres a blue led at the top right of the back of TV that comes on a few seconds after it's turned on which stays on for a few seconds then goes off (this may be nothing but thought worth mentioning)
          so could be the power supply not powering the backlight?
          • anotherdude
            • Feb 2013
            • 488
            ok not sure if i'm on the right track here but from similar looking laptop screens i gather the 2 pin connectors at the top right of the PSU power the backlight, turned the tv on and measured the output neither of them output anything over 0.33v
            now i'm not sure if this is correct as theres no backlight connected but assumed the backlight would need more than this to power up
            • newtothis
              • Mar 2013
              • 1556
              • england
              Careful around back-light voltages.. Inverters are high voltage and can give a nasty shock and blow your diagnostic equipment.
              Can you take some pics of the boards connectors close up
              • anotherdude
                • Feb 2013
                • 488
                hope these are ok, there should be a output though shouldnt there over 0.33v?
                • anotherdude
                  • Feb 2013
                  • 488
                  if i shine a light through the front of the screen with the menu on or whatever should i still be able to see the image even though the light is coming from the front, just to rule out a dead screen?
                    Do you see a pin marked BL ON or ON/OFF?
                    A dead screen would not cause loss of backlight.
                    • anotherdude
                      • Feb 2013
                      • 488
                      I don't see it as far as i can see anyway
                      i found this thread with the same issue and the same power supply so assuming it's just a rebadge like most
                      https://www.badcaps.net/forum/showpo...0&postcount=16
                      From reading about other backlight issues seems it's a inverter issue, but i don't see that board anyway or as a seperate unless it's under the white back but i don't see any cables leading to it from top side or is the inverter built in to the psu on these models?
                      • anotherdude
                        • Feb 2013
                        • 488
                        anyone able to give any direction on where to go from here, testing the backlights or finding out if the image is displayed on screen?
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          Your inverter is built into your PSU.
                          See the ribbon cable in your last pic that folds over into the panel? Follow that and locate the tcon... look on the board for a component label with the start being F.. so F23 / 3A or something similar... test that fuse with your multimeter
                          Also shine a flashlight into the screen in a dark room with an input plugged in.... sky, pc etc .... see if you can see an image
                          • anotherdude
                            • Feb 2013
                            • 488
                            ok i don't see anything on the t-con like that but noticed it seems like a LG panel
                            got a torch on the backside of the screen undeneath and can now see the no signal message bouncing round the screen as I did not connect a device, so safe to assume it is a backlight issue?
                            i know it's pretty common for backlights to die as i see no damage at all psu side, is there a way i can unplug the backlights and power them manually to test them? but then again when i measured the pin output from where the backlight connects theres only 0.33v coming from it which i'd assume is not enough
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              PSU isn't telling the backlights to start....
                              we need to find which pin of the connector is BL-ON, Can you check around the connectors for any writing like 24v, bl-on, gnd etc... if not try looking on the foil side of the PSU instead
                              • anotherdude
                                • Feb 2013
                                • 488
                                this is it i think?
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  Indeed.
                                  Check that pin for DC when turning the tv on and watch the readings...
                                  post back results
                                  • anotherdude
                                    • Feb 2013
                                    • 488
                                    Indeed.
                                    post back results
                                    which pin am I checking?
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      BK
                                      I am assuming this is the back light signal
                                      • anotherdude
                                        • Feb 2013
                                        • 488
                                        BK
                                        ok i used the chassis as ground set the meter into the 200v range and measured at turn on, the reading was 0.00 when turning on and while on both pins next to it measure 0.41
                                        does it matter i'm using a cheapo MM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
