Vizio VO320E Bad Power Supply Board
  • craftech
    • Mar 2006
    • 45
    Vizio LCD TV Model VO320E
    Power Surge in house occurred with unit turned off and plugged in. No picture or sound. No lights.
    Power Board DPS-172EP A (0500-0407-0730)
    Read the following thread which was helpful:
    https://www.badcaps.net/forum/showth...+vo320e&page=2
    Fuse is good
    Checked this large electrolytic cap's voltage in standby = 154 volts
    https://www.badcaps.net/forum/attach...0&d=1376775470
    Bottom of Board:
    https://www.badcaps.net/forum/attach...4&d=1376780218
    Checked the diodes with board removed. All seemed good. Voltage one way only.
    Output on the three 5V pins is good
    But NOTHING any of the three 12V pins. No voltage.
    Anyone know what to check to fix the board?
    Only used boards are available currently.
    Thanks for the help.
    Regards,
    John
    Re: Vizio VO320E Bad Power Supply Board
    What DC voltage do you have at the PS_ON pin?
    This is your board?
    http://assets.shopjimmy.com/media/ca...7-0730-TOP.jpg
    • craftech
      • Mar 2006
      • 45
      This is your board?
      Thanks for responding to my question so fast Bud. I truly appreciate that.
      Yes, that is my board.
      When I put the multimeter negative lead on one of the ground pins and test the hot pins with the positive lead I get the following:
      Around 5 volts on the three +5V pins
      A reading of - 0 on the three 12V pins
      A reading of - 0 on the PS_ON pin.
      Regards,
      John
        OK, the main board is not sending the ON signal to turn on the main power supply, when you activate the power switch, the PWON should go from 0V to >2VDC.
        You should check the fuses and the voltage regulators on the main board next.
        See LDO testing on the link below and report the voltage readings in the proper format.
        • craftech
          • Mar 2006
          • 45
          Got it. Will do.
          Thanks,
          John
          • craftech
            • Mar 2006
            • 45
            I wanted to post a picture of the Mainboard for reference:
            Part Number 071-2271-2846
            http://www.retechtv.com/products/363...dJ9OgodJnQAzw#
            John
              http://assets.shopjimmy.com/media/ca...3208420150.jpg
              • craftech
                • Mar 2006
                • 45
                Fantastic picture. Thanks Bud.
                I watched this YouTube video and tested the main board.
                http://www.youtube.com/watch?v=cNFzBJELFoU
                1. Tested the two gold tipped fuses. 5V both sides on one. 0v both sides on the other. Unit doesn't power on so I couldn't test for 12V each side on the second fuse. Seems like they both are working though.
                2. Tested the Voltage Regulators.
                3. U11 is a 7805. No voltage on input or output pin
                4. U4 is a 1117. Input 5v, Tab and Center Pin 3.27v, Adj. pin 2.03v
                5. U9 is a 1117. Input 4.93v, Tab & Center Pin 2.48v, Adj pin 1.24v
                6. U8 is a 1117. Input 3.23v, Tab and Center pin 1.23v, Adj. pin 0v
                7. U2 is a 1117. Input 4.92v, Tab & Center pin 3.27v, Adj. pin 2.03v
                8. U5 is a 1117. Input 4.93v, Tab & Center pin 2.60v, Adj. pin 1.36v
                9. TUS2 is an EH13A. Input 0.33v, Tab & Center pin 0v, Adj. pin 0v
                10. U24 is a G1084 that has 2 pins connected with the center pin not connected (marked VO). Don't know what to do with that one. Wasn't in the YouTube video.
                Regards,
                John
                  3. U11 is a 7805. No voltage on input or output pin: This one is fed by the 12v power supply, so it will not show voltage reading due to 12v is not turn on yet.
                  4. U4 is a 1117. Input 5v, Tab and Center Pin 3.27v, Adj. pin 2.03v: 1.25 + 2.03 = 3.28V out, OK.
                  5. U9 is a 1117. Input 4.93v, Tab & Center Pin 2.48v, Adj pin 1.24v: 1.25 + 1.24 = 2.49V, OK.
                  6. U8 is a 1117. Input 3.23v, Tab and Center pin 1.23v, Adj. pin 0v: This may be 1.25V fixed V reg, OK.
                  7. U2 is a 1117. Input 4.92v, Tab & Center pin 3.27v, Adj. pin 2.03v: 1.25 + 2.03 = 3.28V, OK.
                  8. U5 is a 1117. Input 4.93v, Tab & Center pin 2.60v, Adj. pin 1.36v: 1.25 + 1.36 = 2.61V, OK.
                  So, you do not see the ps_on changes state at all?
                  Shopjimmy sells EEPROM for this model, it can be bad EEPROM problem but I do not know how you can verify it.
                  • craftech
                    • Mar 2006
                    • 45
                    Bud,
                    Thanks for the detailed response.
                    Maybe I am not sure how to check the ps_on. Is there a way to trigger it to test it?
                    It seems to me that the power surge with the TV off would fry something else besides the EEPROM wouldn't it?
                    There are no lights on the set, nothing.
                    John
                      You can force on the power supply by disconnecting the cbale between the power supply and the main board, then use 500~1K resistor between 5vstby and the PS_ON pin to force on the power supply, you should see the 12v OUTPUT.
                      • craftech
                        • Mar 2006
                        • 45
                        That worked like a charm Bud. I cannot believe how much fun this is and how much I am learning. I can't thank you enough for teaching me.
                        Got 12v on all three pins with a 1K jumper resistor. So then I assume that it is the 5v pins on the P/S that power the circuit(s) on the Main Board that supply 3.1v back to the PS_ON pin on the P/S.
                        So 5v is getting over to the Mainboard OK, but the Mainboard is not generating the 3.1v when you press the Power Button that turns on the 12v section of the P/S.
                        ShopJimmy says EEPROM is U18, but I am not finding it on the board:
                        http://www.shopjimmy.com/vizio-vo320...eprom-only.htm
                        Regards,
                        John
                          You can contact SJ and ask him the question about the EEPROM, he is very helpful about it.
                          • craftech
                            • Mar 2006
                            • 45
                            OK Bud,
                            Will do. Will post back results.
                            Thanks again,
                            John
                            EDIT: Left a message to call me back. Meanwhile I found the U18 EEPROM. It's on the bottom of the Main Board.
                            • craftech
                              • Mar 2006
                              • 45
                              Follow-up
                              I spoke to someone in the tech dept at Shop Jimmy.
                              They didn't think it was the EEPROM because there aren't any lights at all. [Not even the logo is on]. [Correction: See my next post] He thinks the entire set is fried and that I should junk it.
                              Not good news, but they saved me a lot of money replacing power supply, mainboard, and possibly the LCD panel as well. He thinks that the power surge may not have necessarily been through the AC input. It may have come through the coaxial input as well.
                              But I learned an awful lot about LCD TV testing from you Bud and for that I am truly grateful.
                              Regards,
                              John
                                I think you would be a little hasty to throw away this set.
                                We've only ever seen power supplies and main boards damaged by power surges - the LCD panel survives.
                                If the EEPROM is a no go, I would replace the main board.
                                At the very least, chuck it on craigslist for $30 and it will be gone in a day... better than throwing it out and letting it rot.
                                • craftech
                                  • Mar 2006
                                  • 45
                                  OK, my old man eyesight will be the death of me yet. The Vizio logo IS in fact lit up.
                                  All this time I had the panel laying on it's face and was lifting it up to look at the front and didn't see the logo lit up.
                                  I just stood it up on edge and plugged it in and there it was, lit up in yellow.
                                  Now I feel like a fool calling them back. So embarrassing.
                                  John
                                  • craftech
                                    • Mar 2006
                                    • 45
                                    Hello Tom and Bud,
                                    I was wondering if either of you think I should just go ahead and order that U18 EEPROM on the bottom of the Main Board anyway? The part number is very hard to make out, but it looks like MX (Macronix International) 25L32 (50i or 5Di?) Can't find that part number especially the last part. Pix on Shop Jimmy doesn't show a part number at all. $25 non-returnable even if it is the wrong part.
                                    Regards,
                                    John
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      John, I've been following this post and it just clicked in my head that I have this set in my basement with a busted screen. The screen is so severely smashed that I never even attempted to plug it in, but I can get you part numbers if you want. I can't say for sure that the main board works, but I may be able to disconnect the panel from the T-Con, connect a source, and see if I get sound. I know it doesn't prove anything, but it would at least suggest that the main board and power boards are working. Though now that I think about it, as bad as the screen is, I wouldn't be surprised if a bulb or many bulbs are broken too. It may not power up at all. I'll let you know if I have the same main board when I get home in about 5 and a half hours. Where are you located?
                                      • craftech
                                        • Mar 2006
                                        • 45
                                        Thanks a lot John. That's wonderful news.
                                        I am in Upstate, New York
                                        Regards,
                                        John
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • penangit
                                          Hp v193 monitor power supply board
                                          by penangit
                                          Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                          I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                          I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                          Steps taken so far:
                                          Checked all...
                                          02-21-2023, 04:00 AM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • rajbot
                                          No Power problem with Vizio E60-E3
                                          by rajbot
                                          Hi all:
                                          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                          03-22-2023, 08:09 AM
