Sharp LC-60E77UN Backlight Problem
    Hello
    I have a 60 inch sharp lcd tv. I purchased the tv for 200 with a backlight
    problem. After checking tv out I found Master inverter board bad. I replaced
    board and tv worked fine for over a year. I started getting flashing in the
    back lights while watching tv. I adjusted backlights brighter and it helped
    for awhile. Then I had to keep turning brighter untill one day they just
    quit working. I have steady blinking green light and tv will not come on.
    When I try to enter service mode backlights flash for a split second then
    back to blinking green light. I have removed back off set. I have changed
    inverter boards due to having a extra set. My question is is there a way
    to turn/bypass protection off so I can see how many lights are out. Ive
    never changed the backlights in sets so Im a little hesitant untill I can see
    for sure it is a bad ccfl.
    L Leonard
    Re: Sharp LC-60E77UN Backlight Problem
    I believe this is the sequence: With the tv unplugged, hold down the Input and Volume-Down buttons simultaneously, then plug in the tv.
    LG Plasma Mal-Discharge Correction Service
      yes i tried this. backlight comes on for split second than goes out and tv gos to
      protect mode green light just flashes.
        Did you ever find what the problem was? I have a set doing the same thing and don't want to waste money on inverter boards if its burnt out ccfl lamps.
          Had one, found burnt wires on the main inverter[the one on the left]
