Sanyo DP50719 Plasma Turns On & Off w/Clicks
  • barryra
    • Aug 2013
    • 107
    I am working on a Sanyo DP50719 plasma where it turns on with a light grey screen (no image) then shuts off about every 15 seconds & then powers up then cycles over & over. There is a green light on the front & on one of the boards which is on & off when the tv cycle. Thanks for any help.
  • zdsh07p9
    • Nov 2013
    • 155
    Re: Sanyo DP50719 Plasma Turns On & Off w/Clicks
    Hey believe it or not I have the same problem with the exact same TV
    • zdsh07p9
      • Nov 2013
      • 155
      I had to replace the X sustain board before I could get to your situation though. Now it turns on with same problems as yours. Before the newer X was replaced, the TV would cut off in 3-5 seconds. (cut off due to bad board). I also noticed that when I disconnect the Main Board (not the main logic) from the Main Logic board, that the TV stays on regardless.
      • zdsh07p9
        • Nov 2013
        • 155
        Sorry for all the posts, but I am new and we NEED pictures (from my experience on the forums), correct me if these pictures are not the same as your TVs insides. If so I will start a different thread.
        And to clarify, when he says the screen lights up grey, it does but if we press volume up/down or channel up/down we (I think) don't get any reaction on the screen from these actions.
        We need help! I have seen online where it could be logic board or main board issues
        • zdsh07p9
          • Nov 2013
          • 155
          After some more checking, the board that I believe to be the X sustain board on the far right... it's heatsink does not get hot or warm, think I could have gotten a bad X sus from shopjimmy?
          • zdsh07p9
            • Nov 2013
            • 155
            Can connect the Main and Logic board back up when the tv is powered on and it will go back into original problem cycle. 15-20 seconds of on with no picture, then shut off and come back on..
            • cliff_hootarski
              • Jul 2006
              • 411
              http://www.coppelltvrepair.com/p/56/...repair-service
              This may be a cure to your problem.
              • zdsh07p9
                • Nov 2013
                • 155
                Anyone had this same problem? I have a different mainboard instead of the one listed, I have J4FH
                • fxdfireman
                  • Nov 2010
                  • 86
                  I have the same problem with the same set. Turns on for 10-15 seconds then off for 2- 3 seconds and repete. Does anyone know what goes wrong on the main board? I see people offering to repair the boards, is the a common component that goes bad that i could do the repair myself?
                  • fxdfireman
                    • Nov 2010
                    • 86
                    I am going to go through the caps tonight. Is there anything else i should be checking?
                    • fxdfireman
                      • Nov 2010
                      • 86
                      Does anybody have any ideas what goes on these main boards? I would like to try fixing myself.
                      • fxdfireman
                        • Nov 2010
                        • 86
                        Does anybody have any ideas?
                        • Peter Chiu
                          Banned
                          • Dec 2012
                          • 145
                          Hi!!! This is the problem!!!
                          Sanyo Service Tip
                          USIK / YX6E CHASSIS
                          07/27/12
                          If the power LED on front of the TV is turning ON for 10-20 seconds, OFF for
                          SYMPTOM:
                          1-2 second and keeps repeating, the problem is most likely IC5750A. Affected models are
                          the 2009 & 2010 TVs (LCD and Plasma) listed.
                          IC5750A is located under the large shield. IC 5750A is a 48 pin NAND FLASH IC with
                          easy access for replacement. This will fix +80% of the boards with the symptom below.
                          Sanyo Part Number: QXXAVD058- - -M
                          Chassis IC 5700 IC 5700
                          Version Samsung Quimonda
                          P37819-00 SW84 SW82
                          P42849-00 SW84 SW82
                          P42849-01 SW84 SW82
                          P42849-02 SW84 SW82
                          P42849-04 SW84 SW82
                          P42849-05 SW84 SW82
                          P46849-00 SW84 SW82
                          P46849-01 SW84 SW82
                          P46849-02 SW84 SW82
                          P46849-03 SW84 SW82
                          P46819-00 SW84 SW82
                          P50749-00 SW84 SW82
                          P50749-01 SW84 SW82
                          P50749-02 SW84 SW82
                          P50749-03 SW84 SW82
                          P50719-00 SW84 SW82
                          P52449-01 SW85 SW83
                          P42840-02 SW84 SW82
                          P42840-03 SW84 SW82
                          P42840-04 SW84 SW82
                          P46840-01 SW84 SW82
                          P46840-02 SW84 SW82
                          P50740-01 SW84 SW82
                          You must use the 3
                          dashes when ordering
                          this IC.
                          SYMPTOM:
                          for 10-20 seconds, OFF for 1-2 second and keeps repeating, the
                          problem is most likely IC5750A. Affected models are the 2009 &
                          IC5750 to be replaced
                          Check IC manufacture for either Samsung or Quimonda
                          The IC 5750A you receive will have software 84 installed in it. If
                          IC 5700's manufacture is Quimonda or TV is a 52" then the
                          software will need to be changed with the use of a USB drive.
                          Note : Only use this software in the Sanyo TVs listed.
                          If used in wrong chassis, it could cause TV not to come
                          on and IC 5750 will need to be changed again.
                          • Peter Chiu
                            Banned
                            • Dec 2012
                            • 145
                            LINK is here:::::
                            • Peter Chiu
                              Banned
                              • Dec 2012
                              • 145
                              IC5750 needs to be replace. : )
                              Hynix HY27US08561ATPCB HY27US08561A-TPCB TSOP48 IC Chip
                              Flash NAND 256Mb (x8) TSOP 3V
                              And U need to Program it. : (
                              http://www.ebay.com/itm/TNM-2000-USB...item4ac97178bf
                              • pkasongo
                                • Mar 2015
                                Has this fix worked for anyone? I'm having the same issue need to confirm before purchase. Also I saw that someone said there was a need to reprogram?
                                • pkasongo
                                  • Mar 2015
                                  • mostachio
                                    Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                    by mostachio
                                    Hi Badcaps,
                                    I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                    TV Details:
                                    Model # - TH-65DX700Z
                                    Symptoms:
                                    The television turns on and displays a picture then makes a clicking sound and turns off.
                                    I haven't opened it up yet but...
                                    09-04-2024, 02:32 AM
                                  • Stephen
                                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                    by Stephen
                                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                    03-15-2024, 09:37 AM
                                  • www
                                    LG L192WS-BN backlight turns off after 1 second
                                    by www
                                    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                    03-24-2024, 05:26 PM
                                  • Tyrmas
                                    Philips 58PUS6809/12 doesn't turn on - LED turns on for a second and TV clicks
                                    by Tyrmas
                                    Hi all!
                                    A few days ago my TV suddenly turned off while watching Netflix from my media PC. Only connected cables were HDMI and TOSLINK. It immediately started doing this loop where the power led turns on for a second and then turns off. You can also hear a click inside the TV every time.
                                    I tried the easy stuff first like disconnecting everything including the power cord but that didn't fix the issue.
                                    Now I opened the TV to check if there are any bad capacitors but as far as I can tell, they look okay.
                                    I've attached a few pictures and...
                                    08-24-2021, 04:33 AM
                                  • zklgfs
                                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                    by zklgfs
                                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                    08-11-2025, 02:14 PM
