LG 32LG7000 Fault
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    LG 32LG7000 Fault
    Next tv i have is a 32LG7000, sometimes it will power on fine but most other times it stays on a black screen and the backlight goes on then off every few seconds, first day i got it i turned it on and it worked first time but i tested a hdmi in it and if i remember correctly it showed greyed out when i pressed the input/source button as if nothing was connected.. I tried it again last night and it fired up ok so i tested the power board and all values read as they should, Any of you experts out there know what would cause this?? I can post a video if needed but i think i explained the fault well enough there.. :-)
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Re: LG 32LG7000 Fault
    Does noone know how i might go about fixin this? This is the second time i've asked and both times got no reply.. I'm not sure how to troubleshoot it properly.. Where do i start.lol ;-)
    • selldoor
      Slow Learner
      • 7870
      I know v little about tvs but can t tell anything of the problem from your video.
      Have you read Budms guide on troubleshooting lcdtvs stickied on this forum.
      Intermittant faults are very difficult to troubleshoot from a distance.
      You need to test the power board again when it is not working.
      It could be the inverter board post a clear in focus pic of both sides, if it is long/narrow
      do it in overlapped sections. When it is on try gently moving the boards to see if it goes off. Also when it has been working switch it off - does it always come back on when warm. If so try gently heating sections of the boards to see if it comes on.
      • mmartell
        • Oct 2013
        • 3189
        If there is a ribbon cable running from the inverter to the tcon try unplugging it.
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          No mmartell no ribbon from t-con to inverter...
          • munirutech
            • Oct 2013
            • 72
            • Ghana
            if the tv goes dark ,did you get the sound
            • Easky15
              • Sep 2013
              • 285
              • Ireland
              No mate, It's like the tv hasn't fully powered on, Black screen with the backlight flickin on and off, I've tried scart and hdmi inputs in it to see if theres sound but i get no response from any buttons on the set or the remote,
              • Easky15
                • Sep 2013
                • 285
                • Ireland
                Also i tested all power outputs on the tv, 5vstb, 5v, 12v and 24v all working fine
                • Rictech
                  Panasonic SA-MAX770PU SMPSU board fault....
                  by Rictech
                  Hello everyone. 😀
                  As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                  Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                  Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                  This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                  There are no devices that have exploded or otherwise show signs...
                  08-26-2024, 01:05 AM
                • howardc64
                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                  by howardc64
                  • Prior owner tried a replacement main board. No difference.
                  • Samsung 2x red blinking standby LED = panel fault
                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                  07-19-2025, 10:54 PM
                  ESR meter came to the rescue again today with a PLC I/O card fault
                  by sam_sam_sam
                  I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                  I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                  One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                  12-18-2023, 08:17 PM
                • cazi1001
                  Strange fault on Lenovo ThinkPad E14 Gen. 2
                  by cazi1001
                  I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                  The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                  On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                  03-24-2024, 04:16 AM
                • spleenharvester
                  Cordless Dremel 8220 rotary tool power fault
                  by spleenharvester
                  Hi all
                  I bought this Dremel several years ago (8220 + 880 2.0Ah battery). After about a dozen light uses it developed a power fault. I asked Toolstation to start a warranty claim for me and they just refunded me in full without asking for it back instead. Would be nice to fix it instead of consigning to the dustbin.
                  It is complete luck of the drawer whether it powers on or not. Sometimes it will be completely dead, no lights no response. Switching power on and off repeatedly and/or removing and reinserting the battery will eventually make it spring to life. After that...
                  04-13-2025, 02:10 PM
