Strange fault on Lenovo ThinkPad E14 Gen. 2
  • cazi1001
    • Jun 2023
    • Deutschland
    I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
    The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
    On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board took around 100 mA if it is off. I replaced the BQ25710 (Battery Charge Controller) and the single board (without any connections) take around 60 mA.
    I checked every trace with the multimeter and I injected power with the power supply, but I doesn't find any (parcel) short. If I take out the BQ-chip, the board take only 10 mA and this is fine.
    And now, on this point, I haven't any further Idea.
    Had somebody any idea or know this kind of fault?
  • mon2
    • 14685
    1) board runs ok with the type C adapter?
    2) board runs ok if using a pre-charged battery?
    3) board is not charging the battery?
    4) test with another known good battery. Try Amazon since you can return the battery if it is not required.
    5) carefully measure and post all voltages on the charger ic with and without the battery.
    6) double check your soldering of the replacement charger ic. Often the fault is here. Does Windows report the full details of the battery? If not, check the smbus lines on the charger ic and the battery connector.
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • Grafnus
      Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
      by Grafnus
      Hey there,
      first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
      So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
      Specs:
      • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
      • CPU, GPU, RAM work fine (not involved in the Problem)
      So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
      Now I noticed...
      08-06-2025, 11:54 AM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
    • ferah831208
      by ferah831208
      03-18-2025, 01:18 AM
