Panasonic TX-32LZD80 backlight no picture (fixed)
    Re: Panasonic TX-32LZD80 backlight no picture (fixed)
    Just got a TX-32LZD81 in; same model but with Freesat and better speakers. Same fault. Was the same fuse on T-con. Working great now
    • Richiiii
      • Mar 2015
      • 13
      • England
      I was given one of these tv's with the same problem, just fixed it myself using this thread, fuse cost me £3.47 from ebay, iv now got a fully working 32 inch tv for under a tenner including new remote...... Well chuffed!! Thanks for the great advice all.
      • Mike_B
        • Jul 2015
        Hi guys,
        sorry to necro this thread however I stumbled across the forum whilst trying to find out how to fix my tx-32lzd80 which went the other day.
        Symptons are similar to all described in this thread, so I've gone away and bought some of the fuses that Tom linked from cpc.. the only trouble now is they've arrived and I have no idea how to fit them!!
        Any advice please?
        Thanks, Mike
        • flocko
          • Nov 2012
          • 1121
          did you check the fuse to see if it had blown ? if yes ,you can put it on top of old fuse don't need to take old one off, hold new over old then just solder end to end job done, if you take old fuse from board it can be hard to get new fuse soldered on small tabs if your iron is to large Flocko
          • liam
            • Oct 2015
            • 11
            • Ireland
            Great advice floco, just volunteered to fix my brothers tv, (same problem) and found this thread,.. brilliant!! My thanks to all the subscribers to this excellent thread.
            liam
            • captainhook
              • Nov 2015
              Many thanks for this invaluable advice - just fixed my TX-32LZD81 with the same symptoms and fault. Daughters are delighted to have cbeebies back...
              Not about to post a picture of my shoddy soldering, which was nearly disasterous... but it works!
              Cheers
              Ben
              • Paultrucker
                • Feb 2016
                • 3
                • France
                #27
                Fault on TX43LZD81
                I have the same TV which presents the same problem. I have removed the back and tested the two fuses responsible for a no picture situation. We have no picture but do have sound. When I tested the fuse in your pics it reads a little over 14v the other one for the 12v feed just to the right of the board connectors below the T-con board PA7001/JS7065 reads 0.01v but the one below (C7122) reads a little over 14v too. I saw the second one identified as faulty in the only YouTube video, it was not particularly well presented but did lead me this far so I'm thankful. This TV is critical to my wife's viewing as she has an illness that prevents her being able to use multiple remotes for separate satellite box etc. she's missing it. Last question, if I cannot get the correct component can I solder a 12v 2amp fuse in situ, perhaps in a fuse holder? I am willing to invest in a new soldering iron, mine is a bit of a poker. Recommendations for something moderately priced and adequate. Please bear in mind we live in the sticks in NW France, read dark ages for choice and availability. Delivery is also painfully slow, quicker to buy and ship from the UK!
                Thanks in advance, Paul
                • spareclaire
                  • Mar 2016
                  #28
                  I don't know how to solder fuses etc but I found a t-con board on eBay and just managed to fix my TV thanks to this! You stars!
                  • Kidontheslope
                    • Nov 2016
                    • England
                    #29
                    Kind of reviving a dead thread here,
                    I've got a 'no-picture' TX-32LZD81 here, replaced the fuse with a glass type temporarily (1206 ordered) and the TV works again!
                    For the people that have done this fix, how long has it lasted for?
                    I had a look at the rails, and I have some 50Hz pulses on the 12V (the one with the fuse) and the 6V rail is sitting at 6.6V due to some ringing and again 50Hz.
                    Anyone know where I can get schematics/service manuals from, preferably free??
                      Think there are schematics on my website (below). The first set I fixed is still going (must be at least 3 years) and no complaints after my 6-mo warranty for the other set.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #31
                        heres the link for toms website not sure why its not showing in his above post
                        http://www.toms-service-manuals.com/
                        • TVDavid
                          • Sep 2015
                          • Conwy
                          #32
                          Thanks for the information.
                          The fault was the fuse on the T-CONN board of a Panasonic LCD TX-32 LZD81.
                          Fitting a replacement from CPC cured the fault.
                          • trydowave
                            • Jan 2014
                            • 8
                            • England
                            #33
                            i just picked up a Panasonic TX-32LZD80. same problem with the screen.
                            When i turn it on i get a faint blueish glow from the screen. I tried putting a flashlight up close to the screen to see if I could make out the menu but couldn't.
                            Does that mean the tcon board is dead rather than the lcd driver?
                            Also. Ive been reading this thread. If it really is a simple a fix as suggested then thats great but, my soldering skills are BAD!, my equipment is old and not very good and this fuse looks tiny!
                            How hard is it too do? are there any videos demonstrating the fuse replacement?
                              Your problem is most likely the fuse on the T-con
                              We can't rule out other possibilities unless you are prepared to get a multimeter out and start testing things
                              The fuse is pretty easy to replace but you'll need an intermediate level of soldering ability.
                              • trydowave
                                • Jan 2014
                                • 8
                                • England
                                #35
                                thats what i dont have... or the knowledge regarding the testing. Got two tvs here.. the one mentioned here and an old phillips flatline 37. The latter was a great old TV but it looks like its finally bit the dust. (flickering light error).
                                Unfortunately looks like im gonna have to take these to the dump.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  if you have or can borrow the tools we can talk you through the testing and repairs
                                  • trydowave
                                    • Jan 2014
                                    • 8
                                    • England
                                    #37
                                    i have a multi meter... a crap cheap soldering iron and some solder (from the 50s) and a few electrical screwdrivers etc.
                                    would that be enough?
                                    • Vi-Fo
                                      • Jan 2020
                                      • Kolin
                                      #38
                                      Dear, it is very good advice! TV works excellent! In first time I traid fuse RXEF185 and now I have to bay fuse SMD1206 24V 1.6A.
                                      Thanks!
                                      • SheriffBuck
                                        • Jan 2020
                                        • 3
                                        • United Kingdom
                                        #39
                                        Similar issue here with a UK TX-32LZD81. Fuse on TCON board replaced with one of these from Farnell.
                                        BOURNS SF-1206S160W-2
                                        https://uk.farnell.com/bourns/sf-120...206/dp/2855088
                                        Farnell part no: 2855088
                                        Thanks to all the contributors. Another TV saved from landfill!
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Bazfletch3
                                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                          by Bazfletch3
                                          Hi all
                                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                          From there I envisaged that the backlighting wasn't working, however...
                                          01-08-2024, 10:18 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          Yesterday, 12:34 AM
