Help with inverter board - pics attached
  • adtamez
    • Oct 2013
    • 9
    • US
    Hello all,
    First of all I want say thank you to all of you because I have learned a lot from it. I am a newbie trying to fix his TV.
    I have a 42" Digital Lifestyle TV that after just watching a movie the screen when black. The external power LED turns green and stays green. And I can hear the turning in on clicking sound. So my conclusion by reading this forum was to check the inverter boards. And as expected, the capacitors on each inverter board (master and slave) are bulged.
    Anyways, I have ordered the new capacitors and I am just waiting for them so I can replace them. However while I was disconnecting the cables from the inverter board I accidentally pull to hard and broke the shell that protects the pins where a cable connects. I don't know how this part is called but take a look at the pictures.
    What do you guys think? Can I fix this? I am really new to soldering but i have manage to fix some easy projects.
    Is this little broken piece important? or is it just there to glue the pins shell to the board and I won't have a problem without it?
    If it is important do you have any tips on how to solder it again? It is a very very small tight place that I don't think my soldering iron tip will fit in there.
    Please help!
    Thank you so much in advance.
    Re: Help with inverter board - pics attached
    That is just the connector holding tabs so it will stay on the circuit board, the male pins are the one for electrical contacts.
    • adtamez
      • Oct 2013
      • 9
      • US
      Thank you sooo much budm! I am happy to hear this...I am sorry for my newbie-ness
      Just to make sure I understood correctly, you do not think that I need to fix/solder this, correct?
        As long as the connector will stay in place, you will be OK.
          A small bit of glue may be advisable but that is all.
          • truep
            • Aug 2010
            • 373
            isn't there a pin showing on the fragment? It looks like it in pix 3, and 4.
            • adtamez
              • Oct 2013
              • 9
              • US
              Great news! Thank you all for you help.
              Fortunately, it's just the corner. There is no pin on it. What you are seeing on the last pics is just a small plate but no male pin on it at all.
              The capacitors for the inverter board just arrived. I'll keep you posted if that fix the problem.
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • jasonbay13
                Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
                by jasonbay13
                it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
                PU200
                pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
                pin 8 vreg3 = 0v
                pin 13 en = .2v
                pin 1,6 entrip1,2 = 0v
                b+ and b++ = 19.5v
                +5valw = 0v & 25+ohm to ground
                +3valwp = 0v & 25+ohm to ground
                i cleaned the board up just a little and can get more pics.​
                where should i be looking? thx...
                09-25-2025, 10:54 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
