Z50PJ240 Powers on then back off clicks but no picture
+ More Options
Posts
  • tw2005
    • Oct 2011
    • 6458
    Re: Z50PJ240 Powers on then back off clicks but no picture
    Originally posted by soog35
    TW and TOM
    I got the new PSU but haven't installed yet. The D304 diode seems to be open, so this could be defective. I have a pic of the diode and a video link of me testing it. Do you guys think this would give me trouble if I install this as is. I don't want to mess up anything else. I still have a good diode I could replace it, or maybe I need to send it back. Does it look bad to you guys?
    http://www.youtube.com/watch?v=q-U5mcdy2kA
    Is the board on the left the replacement? Vidoe left your right as you stood.
    • soog35
      • Oct 2013
      • 55
      • usa
      #102
      Yes, the board on the left is the new one.
      • tw2005
        • Oct 2011
        • 6458
        I'm trying to understand your meter but I assume in continuity mode but displaying ohms? 0.7 ohms and constant continuity beep is what you will get there. I get 0.6 ohms and dead short in continuity test but we've discussed this as the diode is sitting across a 0.26ohm resistor.
        Your other board is wrong , maybe resistor is open?
        • Brentsky
          • Oct 2013
          • 46
          D304 tests open both of my PSU's with the 3 5w 10ohm resistor setup and both boards are good.
          • soog35
            • Oct 2013
            • 55
            • usa
            #105
            So the new board is correct because of the resistor that is parallel and the old one on the right is bad then?
            • tw2005
              • Oct 2011
              • 6458
              what do you define open by on the meter? Can't be open across a 0.26 ohm resistor. open would be OL, short or low ohms I get 000 on continuity, 0.7 ohms in resistance on an old fluke.
              what does your meter display and in what setting?
              My board is good too.
              • tw2005
                • Oct 2011
                • 6458
                what you have at that point on the new board is correct and the same as mine.
                What you have on your old board is wrong.
                • soog35
                  • Oct 2013
                  • 55
                  • usa
                  #108
                  ok thanks, good to know. I was going by a diode video test that if it was beeping it was opened and probably bad, but it was an out of circuit test by itself.
                  So if it were out of circuit would it test differently?
                  • tw2005
                    • Oct 2011
                    • 6458
                    yes, out of cct current flows i one direction , not the other. So effectively open cct one way, and could be 0.4-0.5. in diode mode.
                    You seem very concerned about this diode.
                    • soog35
                      • Oct 2013
                      • 55
                      • usa
                      #110
                      Sorry...lol just trying learn and understand things better.
                      • tw2005
                        • Oct 2011
                        • 6458
                        That's ok. So am I, I think I'm as nervous as you about what happens next. hope it's a happy ending.
                        • soog35
                          • Oct 2013
                          • 55
                          • usa
                          #112
                          Going on 2:00am now, I will have to wait till morning to hook it up. I will let you know what happens.
                          • tw2005
                            • Oct 2011
                            • 6458
                            No doubt, good idea to give it a break, most silly mistakes happen due to fatigue.
                            • soog35
                              • Oct 2013
                              • 55
                              • usa
                              #114
                              I put the PSU board in and so far working great. Been on for 6 hours so far.
                              A big thanks to everyone who helped me, especially Tom and TW. You guys are awesome.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Good one, full marks to Tom though, he sussed this one out I think. I just wanted to cover the sustains just in case a dead short possibly did any damage.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Hey TW thx for the info. I must have jumped the wrong link or something cause it was showing $122 and 0 in stock on the ysus but that wasn't the green choice. I pulled all the buffer boards out and not a single spot that even looks close to like anything would have happened to them . I guess for now I'm gonna wait on the replacement Ysus board and am also gonna order a ysus/zsus and buffer board set from your link. It's worth the $100 to get this going again. I had previously checked the zsus board and saw no signs of any damage to that either however we all know not all problems are easily visible. I will certainly post back once I find the culprit.
                                  For info, https://www.badcaps.net/forum/showthread.php?t=32580
                                  Ysus only did not fix this one, sounds like the new ysus may havew popped.
                                  • Brentsky
                                    • Oct 2013
                                    • 46
                                    OK so I got the new Ysus board and Zsus boards in today and replaced them. it was immediately better than the previous Ysus replacement and had a normal looking picture until it got to the center of the screen and there was some distortion. then it went away on it's own after a minute. then I come back to the TV about 10 minutes later and there is a big black bar down the center of the TV. if I turn the TV off when I turn it on it flashes multi colors on that bar until the picture comes up and then it's just the black bar. any ideas as to what would cause this ? Bad Zsus replacement board ?
                                    • Brentsky
                                      • Oct 2013
                                      • 46
                                      Also I placed the old Zsus board back in and turned it on and it was all greay again and distorted so I'm certain the old Zsus was failed as well. after placing the new zsus back in the black bar has colored lines poping all over it but I can see the cable menu bar under those colors ? Hope that info helps in pointing me in the right direction . I'm so close here ... Just want my TV working. Thanks
                                        Reseat the connector on that part of the bottom of the panel, horizontal axis of panel. Bad Z-sustain cannot cause this. Do not reseat while power plugged in.
                                        • Brentsky
                                          • Oct 2013
                                          • 46
                                          Thanks Tom66, Do you mean from the buffers on the bottom to the panel ?
                                          • PNI E.
                                            tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                            by PNI E.
                                            hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                            02-20-2025, 08:36 AM
                                          • sergio_av
                                            Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                                            by sergio_av
                                            Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                                            Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                                            When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                                            Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                                            01-01-2025, 05:27 PM
                                          • KYBOSH
                                            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                            by KYBOSH
                                            Saved this beast from the landfill this weekend.
                                            Manfactured July 2013 in Mexico.
                                            I love working on plasma TVs.
                                            Its been a while but I was lucky enough to find 2 this week.
                                            The TV powers on and stays on but no picture. Havent checked for sound yet.
                                            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                            Will start troubleshooting tonight.
                                            10-17-2024, 01:17 PM
                                          • dronerat
                                            Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                                            by dronerat
                                            Hi Guys,
                                            This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                                            PSU: L48S6 FHS BN44-00807D
                                            T-Con: BN95-01937A
                                            Panel: CY-GJ048HGLVLH
                                            MB: NA (Currently as the TV is assembled and forgot to take picture)
                                            As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                                            It was sent to an authorized service for repairs and returned with the...
                                            05-15-2020, 08:03 AM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
