le40r87db screen but no picture
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all got a Samsung in it was a clicker so replaced both the psu and mainboard
    even tried a tcon board in it the same one lads
    but still no picture screen lights up no menu no nothing
    could this still be a powedr issue will do usual checks soon just throwing this one out there see if anyone has any ideas
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: le40r87db screen but no picture
    Any help here this one got me head battered just come across another thread simliar problem going to do what tom says and test the components on lower side of both the t-cons
    i just replaced main and psu
      Check the DC voltage on both ends of the fuse on the T-CON with ref to Chassis ground?
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • arbitarytwist
        Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
        by arbitarytwist
        Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
        Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
        03-01-2025, 01:16 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • nasdaa
        Packard Bell Kayfo, no picture on screen.
        by nasdaa
        Hello, I need your help for a failure on a laptop:
        It's a Packard Bell Kayf0, motherboard LA-5021P, Rev 1.0 with graphic issue.
        I received this pc because it was turning on but not displaying anything, the fans are running normally and all chipsets heat up on startup but no picture on screen, no backlight either. I noticed that ENAVDD and ENVDD are not present and that there is no LCDVDD on the connector. I didn't check the screen because, maybe I'm wrong, but if there aren't these signals, even if the screen is good, it can't display anything? I tried heating the...
        06-20-2023, 01:27 AM
