le40r87db screen but no picture
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all got a Samsung in it was a clicker so replaced both the psu and mainboard
    even tried a tcon board in it the same one lads
    but still no picture screen lights up no menu no nothing
    could this still be a powedr issue will do usual checks soon just throwing this one out there see if anyone has any ideas
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: le40r87db screen but no picture
    Any help here this one got me head battered just come across another thread simliar problem going to do what tom says and test the components on lower side of both the t-cons
    i just replaced main and psu
      Check the DC voltage on both ends of the fuse on the T-CON with ref to Chassis ground?
      • Mgiffune
        by Mgiffune
        I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
        I ordered a supposedly β€˜new' Tcon board this time, and
        06-09-2024, 10:28 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • arbitarytwist
        Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
        by arbitarytwist
        Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
        Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
        03-01-2025, 01:16 PM
      • nasdaa
        Packard Bell Kayfo, no picture on screen.
        by nasdaa
        Hello, I need your help for a failure on a laptop:
        It's a Packard Bell Kayf0, motherboard LA-5021P, Rev 1.0 with graphic issue.
        I received this pc because it was turning on but not displaying anything, the fans are running normally and all chipsets heat up on startup but no picture on screen, no backlight either. I noticed that ENAVDD and ENVDD are not present and that there is no LCDVDD on the connector. I didn't check the screen because, maybe I'm wrong, but if there aren't these signals, even if the screen is good, it can't display anything? I tried heating the...
        06-20-2023, 01:27 AM
      • burbutsalos
        LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
        by burbutsalos
        Hello everyone.
        I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
        The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
        The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
        The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
        The effect is there even on a completely black screen.
        The screen...
        10-21-2023, 02:57 AM
