Panasonic Viera Plasma TC-P60S30
  • redbank
    • Oct 2013
    Hoping someone out there can help me out. I have only had this TV for 18 months and very little hours on it. First all 3 of my HDMI ports have failed, I now have to use video cable to get a picture from my cable box . The HDMI ports have gone over the course of owning the TV but last night I had no picture and now I have a trouble code 13 blinking from the red led light on the front of the TV. Doing some searching I haven't been able to come up with a manual to try and troubleshoot my problem. I do have the manual from my purchase but it doesn't tell me anything including why there is a red blinking light . What I have found from searching is possibly my DG board could be bad (not even sure which part this is)? I have tried following some links from other posts but haven't had much success.
  • redbank
    • Oct 2013
    Re: Panasonic Viera Plasma TC-P60S30
    Update on the situation. The TV actually turned yesterday on and I had a picture and then I turned it off and about an hour later tried turning it back on and nothing. Very frustrated at this point.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      I wouldn't know where to tell you to start on the troubleshooting on this one but I do have both the X Main, Y Main, and all the buffers on hand for this set. If you end up needing any of those, shoot me a PM.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Not sure if it flows down to your model but on mine 13 blinks means "communication error between IC8001 and IC1100" Def A board
        Liberating magic smoke one part at a time
        • aaronwt6
          • Apr 2013
          • 855
          • US
          May just need to reseat a ribbon cable if it's a communication issue.
          • badcappo
            Dead Panasonic Viera TX-P65STW50 Plasma TV
            by badcappo
            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
            Diode type G972s6 - D101 with a short
            Mosfet 06N90E - Q301 shorted
            Fuse T5AH 250V - F103 blown
            Diode D301 shorted
            Relay DG1U-17VDC II - RL001 blown
            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
            11-24-2024, 11:27 AM
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • Eaglecrest
            Panasonic plasma color stripe
            by Eaglecrest
            I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
            11-05-2025, 06:16 PM
