LG 37" lcd tv won't respond to remote
  • Meterman
    • Sep 2013
    • 9
    I have an LG 37lc7d tv that won't respond to the remote control unless you insert a small headphones jack into the TV's "remote in" plug on the back panel. This usually does the trick until the next day, same problem again.
    Also, second problem (possibly related), when the tv does work, the "setup" screen will flash on & off which gets real annoying.
    Any ideas?
    Thanks!
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: LG 37" lcd tv won't respond to remote
    Sounds like the remote jack is shorting out to me, You would have to open the tv to see if it is easily dis-connectable to isolate.
    Liberating magic smoke one part at a time
      That is very common problem due to switching contacts inside the jack that select between the internal IR receiver and the External. You have spray a little contact cleaner inside the jack and insert the mini jack in-out bunch of times to clean the switch contacts.
      • Meterman
        • Sep 2013
        • 9
        Thanks for responding, tried both suggestions, cannot disconnect the jack without desoldering it.
        Set worked until I shut it down for about an hour, now same problem but now it won't respond even if I plug in the mini jack.
        Possible I have a bad main board?
        Thanks.
          If you plug in the minijack then the front panel IR sensor will be disconnected, the jack is make for External IR receiver.
          • Meterman
            • Sep 2013
            • 9
            Sorry, I didn't leave the mini jack plugged in., I worked it in & out several times to try to clean it out. I also used contact cleaner. still no results.
              Shall we continue in this thread only?
              3.4V is checked on the power board, you would need to disassemble the TV.
              Since cleaner+mini jack worked once, I'd just try it again, it might be very contaminated.
              • Meterman
                • Sep 2013
                • 9
                Thanks for the tips, set still won't work. Now it won't respond to panel controls either. I will be opening it up & testing for the 3.4 volts.
                I swear I've had it opened up so many times that I'am gonna put snaps on the rear panel. If no 3.4 volts are found, what should I check next?
                  Generally 3.4V will measure low on these sets e.g. 2.5V which causes a variety of problems.
                  • cstout
                    DeLonghi AC Remote only accepts 3V
                    by cstout
                    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                    I can't find any schematics...
                    06-03-2024, 03:53 PM
                  • valvashon
                    Samsung UN55FH6030CXZA main board USB jack indentification
                    by valvashon
                    Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
                    I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
                    01-23-2025, 11:17 AM
                  • Mc_Millian
                    Toshiba 50lf711u20 fire tv remote not pairing
                    by Mc_Millian
                    I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                    The Tv model number is: 50lf711u20 Rev B.
                    I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                    I've tried 3 different remotes which should be fully compatible with this TV.
                    Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                    The power button, along with the volume,back,select, and directional...
                    04-07-2022, 12:15 PM
                  • edugimeno
                    HiSense 55A7500F won't obbey to remote after power on
                    by edugimeno
                    Hi! I have this TV set that does the following:
                    1) I press the red power button on the remote
                    2) The TV turns on normally
                    3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                    4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                    Then after it's off, it would again accept the TURN ON from the remote and same again
                    BUT:
                    -The remote does show the correct IR beam while observed thru a phone camera
                    -The TV works fine while using the MiRemote...
                    03-14-2023, 11:22 AM
                  • tmhobadcap
                    Pioneer VSX-522-K remote control not working???
                    by tmhobadcap
                    I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                    At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                    12-24-2020, 01:44 AM
