Panny 50PZ80u
  • niqht
    • Sep 2013
    • us
    Panny 50PZ80u
    classic problem child that is now giving a code 4.
    Here is the story ...
    Was my parents, been sitting in the garage for 2 years. Once I finally got to it, it had the standard code 10 so ordered a cap/IC kit. As a quick check until it arrived I grabbed some regular long stem electrolytic caps from Frys and stuck 'em on the 201 & 301. It started right up. But to test, I left it on over night. In the morning it was off with a code 4. Nearly everything I find on these TV's is the 2/10, almost nothing on a 4 other than it is also P related. My question then, is the standard cap/IC repair related to a 4? If not what other direction do I go with this, or is it even worth it at this point?
  • R_J
    • Jun 2012
    • 9625
    Re: Panny 50PZ80u
    This is the code from the manual... 4 Blinks = Power SOS P-board
      Re: Panny 50PZ80u
      4 blinks is likely due to a shorted sustain board, SC or SS. The sustains are rare failures, from memory they are pretty cheap. It may have failed due to inadequate cooling - the case being off means the fan airflow won't work properly.
      • niqht
        • Sep 2013
        • us
        Re: Panny 50PZ80u
        Hmmm... so i potentially broke it more than it was. I have not powered it since then, so I guess I'll just have to get my IC kit on when i get a chance and see if it does it again.
        • truep
          • Aug 2010
          • 373
          Re: Panny 50PZ80u
          Replace those Fry' s caps too. Order Panasonic FM or FC caps from digikey. The caps you have from frys don't have the ripple current or esr needed in a switching power supply.
          • AWTVs
            • Jun 2014
            • 27
            • US
            Re: Panny 50PZ80u
            Hey Panny - did you ever figure out the 4 blink code? I have the same model and replaced the 201 & 301. It worked perfectly for about a month now but it just went out and is blinking 4 times.
              Re: Panny 50PZ80u
              Try starting the set with the SC and SS boards unplugged. If the TV goes to 6, 7 or 8 blinks then the fault is with the SC or SS board.
              • AWTVs
                • Jun 2014
                • 27
                • US
                Re: Panny 50PZ80u
                I sent the power board off for repair. They found a bad mosfet and fuse. After I received back and reinstalled it powered up fine. After 30min of testing, it simply powered off and began flashing the 4 code. The following day I plugged it in and it once again came on and started working as expected. In my novice opinion, it appears that it may be a heat issue with the power supply. Any suggestions would be appreciated.
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
                • Stephen
                  MacBook Pro 14" M1 Pro Battery related question.
                  by Stephen
                  Board was just repaired, great thing for us since the DATA was recovered, however the battery was just replaced with a brand new OEM battery and holds the charge well, I plug it in and the charge icon comes on (lightning bolt) then it goes off and comes back again and repeats itself, The MagSafe 3 Amber light is turning off and on constantly, which is telling me something else is going on, before I pull this board out again I was wondering if anyone has come across this issue since its a little new to me on this model. Battery is holding the charge well at 52% but it won't charge further, I checked...
                  02-12-2025, 04:41 PM
                • spleenharvester
                  Weirdly specific reboots on a TrigKey S5 that seem to be power supply related.
                  by spleenharvester
                  I have two of these mini PCs: TrigKey S5 with Ryzen 5700U, 32GB RAM, 1TB NVMe SSD, Win11 Pro. They work very well for most uses. They are powered by a HuntKey 19V 4.74A brick with a standard DC5525 tip, which feels decently heavy.
                  When the brick is connected to the system through a 1 meter DC female-male extension cord (18AWG so decently thick), the system will black screen and reboot when multiple objects are sliced simultaneously in PrusaSlicer. One object is OK. Literally any other activity on the PC is OK. It is just this one specific thing that causes a reboot. I tried running...
                  09-15-2025, 08:43 AM
                • badboyzzz
                  A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                  by badboyzzz
                  I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                  12-28-2024, 02:11 PM
                • Sephir0th
                  HP ZBook 15v G5 - Weird behaviour/issue related to USB-C/TBT
                  by Sephir0th
                  Hello community,
                  This will be the device of your nightmares. I can't count how many hours I spend to fix it, but it was already way to much...
                  However, I really hope for some insight from experience because I have this nice HP ZBook 15v G5 here which came in completely dead, even +VREG3 not working although it wasn't shorted. Previous repair attempt by a somehow professional repair shop, since I noticed action around the controller responsible for +3VALW and +VREG3 without it making worse. Way later I noticed the PCH was replaced and even later I realized +3VALW...
                  10-05-2022, 04:09 PM
