Samsung smart tv: Model:UN46D6003SFXZC doesnot turn on
  • Nish
    • Sep 2013
    • 124
    Re: Samsung smart tv: Model:UN46D6003SFXZC doesnot turn on
    can you give me the names or the link that I can buy please?
    how about this one?
    http://www.ebay.ca/itm/New-Capacitor...item4175e7da47
    i want to get one better one, so i can use it in future also.
    • Nish
      • Sep 2013
      • 124
      is there anyone has the schematic diagram for "BN44-00423A" power supply?
        These are supposed to be decent
        http://www.ebay.ca/itm/1PC-Transisto...0435d91&_uhb=1
        I do not have a schematic for the *432 power board, I expect Samsung have not released it.
        • Nish
          • Sep 2013
          • 124
          Thank you tom, i will buy that and this one i have to unsolder the capacitor then test it, am i right? alright, i will try to check the 5V line while i wait for this ESR meter and i'll update my work to get some help .
          • truep
            • Aug 2010
            • 373
            I have that tester and it works fine. Yes you will have to take the cap out. there isn't a reliable way to test most caps in circuit as there are other components attached.
            • Nish
              • Sep 2013
              • 124
              thank you truep, once I get the tester I will remove the capacitor and test it. also can you tell me how do you know that the capacitor is good or bad with that tester? because I am new to that tester. can you tell me please truep?
              • Nish
                • Sep 2013
                • 124
                I am waiting for my ESR meter to do the capacitor test, however I recheck the board by looking carefully and I found a 223j 1000v capacitor look different for my eye. is it normal or it might be the problem guy for my tv? can anyone check my images and tell me if this capacitor look normal or not.
                  Just check its value with cap meter to see if read the correct value.
                  • Nish
                    • Sep 2013
                    • 124
                    oh ok, so I have to wait until I receive my ESR meter, I ordered last week. thanks and I will replay after I check with the meter, what value I read.
                    • Nish
                      • Sep 2013
                      • 124
                      finally I received my ESR meter and here are the reading of the capacitor....
                      Capacitor ---------> Reading Value
                      560uF/25v ---------> 598.0uF ESR = 0.02ohm
                      560uF/25v --------->598.0uF ESR = 0.04ohm
                      390uF/25v --------->431.8uF ESR = 0.04ohm
                      560uF/25v --------->616.3uF ESR = 0.03ohm
                      47uF/50v --------->46.59uF ESR = 0.11ohm
                      22uF/50v --------->22.64uF ESR = 0.32ohm
                      22uF/50v --------->23.46uF ESR = 0.32ohm
                      47uF/50v --------->48.02uF ESR = 0.11ohm
                      10uF/50v --------->10.04uF ESR = 0.34ohm
                      10uF/50v --------->10.54uF ESR = 0.30ohm
                      68uF/200v --------->61.97uF ESR = 0.66ohm
                      8.2uF/400v --------->7791nF ESR = 3.3ohm
                      223JS/1000v(NPPS.B32PP) --------->22.13nF
                      105k/350v (SB29FMPE) --------->958.0nF
                      is there anyone point me out which capacitor is need to replace please?
                        Those caps look absolutely fine to me.
                        • Nish
                          • Sep 2013
                          • 124
                          any idea what could I check on the board? also there are few caps that I didn't test with ESR meter. I have attached the picture. do I need to check the capacitor on the image?
                            That's a class Y capacitor, it wouldn't cause any problems.
                            Sometimes, the time invested in fixing a board can exceed reasonable replacement costs. Perhaps start browsing eBay, shopjimmy, etc. for a replacement PSU.
                            • Nish
                              • Sep 2013
                              • 124
                              so if I get new PSU it'll work? and I will look up and try to get it.
                              • Nish
                                • Sep 2013
                                • 124
                                can anyone tell me how do I know the capacitor is good or bad, when I use ESR meter? is there any chart to see? if yes can anyone show me please?
                                  My general rule is:
                                  >2200uF: ESR < 0.05 ohm
                                  >1000uF: ESR < 0.06 ohm
                                  >100uF: ESR < 0.2 ohm
                                  >22uF: ESR < 3 ohm
                                  Note, there is some leeway in these values. Most failed capacitors measure in the multi-ohm range; a capacitor measuring 0.06 ohm but 2200uF may well be fine.
                                  • Nish
                                    • Sep 2013
                                    • 124
                                    I got the new Power supply board and installed into the tv. now the backlight on, however when I connect the mainboard to power supply and try to turn on, it's not turning on? is there anyone has any ideas, what should I try?
                                    • Nish
                                      • Sep 2013
                                      • 124
                                      there is no any power light in front of the tv? do I need to put the back cover and then turn on?
                                      • Ltank
                                        • Jun 2013
                                        • 776
                                        I have a 55" version in the shop. The 5vdc A side was steady. The B side 5vdc cycles on/ off. The set will not turn on. Got a new P.S it did the same. It was sent back. Jumping the
                                        A side 5vdc that was fine to the P.S.-On and the B side 5vdc still turned on/off. Can't find any schematics for the P.S.
                                        • Nish
                                          • Sep 2013
                                          • 124
                                          do I need to change the mainboard? does it give trouble now? I am confused...... help or any idea please????
                                          • x_orange90_x
                                            Samsung UA40J5200AK missing Smart features?
                                            by x_orange90_x
                                            I picked up this TV a couple days ago and it's SUPPOSED to be a smart tv, however it doesnt have any apps or wifi settings to change. I cannot find this EXACT model, it's actually a slight variant that is turning up this information. This is a UA40J5200AKXZN.
                                            The interesting thing about this tv is where it was made. It was made in Egypt. The closest information that I can find that could apply to this model is the following website:
                                            https://www.google.com/url?sa=t&sour...-ua-40j-n5200-...
                                            10-24-2024, 12:29 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
