Samsung smart tv: Model:UN46D6003SFXZC doesnot turn on
  • Nish
    • Sep 2013
    • 124
    I turn on the tv, it doesnot turn on and there is no any led indicating signal on the TV. totally black screen. I opened the tv and verify the powersupply board and there is no any bad capacitors. Also i disconnect the cable coming from the main board to power supply, then the backlight on and off every 10 seconds. can anyone help me to troubleshoot this tv Please. I have basic knowledge of electronic and I am eager to troubleshoot this TV.
    Power supply Model: BN44-00423A
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung smart tv: Model:UN46D6003SFXZC doesnot turn on
    Well I would start with voltage checks from power supply to main board. sounds like a main board issue but don't jump to conclusions yet. Are you getting 5v standby?
    • Nish
      • Sep 2013
      • 124
      thanks for the reply. i measure the voltage at the cable goes to main board. the 5VDC is not stable. when i measure 5.3V display then goes to 2.3V then 0V. i measure again it starts 5.3V then 2.2v and 1.3 voltage. also the pin 9 should give 12.8V (Vamp:12.8V), but i got 0V.
      • truep
        • Aug 2010
        • 373
        Are you sure your meter is set to DC volts? Sometimes Meters set to AC do dhis! Don't ask how I know!!
        • tibimakai
          • Jan 2012
          • 3680
          Did you measure the STBY 5V right, not the Reg_5V.
          • Nish
            • Sep 2013
            • 124
            hi truep, my meter sets to DC Volts
            • Nish
              • Sep 2013
              • 124
              hi tibimakai, i didnot see any label name "STBY" on my power supply board.
              • Nish
                • Sep 2013
                • 124
                I have attached some pictures of my Power supply boards
                  Fast track guide in case it helps
                  • Nish
                    • Sep 2013
                    • 124
                    hi tom66, using your service manual, i found the standby voltage Pin (pin 4) and it should be 5VDC. However when i measure at that pin, it reads 5.3V, 4.2,1.2,4.1,5.3,2.5 so on.... it does not stable voltage. it keeps change to lower voltage then come back to 5.3V and repeat same thing. also i did
                    Forced Backlight -On Mode:
                    1.Disconnect Power Cord
                    2.Disconnect wire harness from CN201
                    3.Re-Connect Power Cord
                    4.LED Backlight should immediately turn on
                    However the backlight turn on after few second and turn off immediately and repeat on and off. it does not turn on continuously.
                      That is because the PS_ON, BL_ON line have the pull-up resistors that getting the voltage from the standby power supply, since the stby power supply output is jumping around so that is why the backlights are turning on and off. You need to fix the standby power supply. It may have bad start up cap in the stby power supply section.
                      • Nish
                        • Sep 2013
                        • 124
                        ok budm, I'll check that and post it. I hope I can find that.... can you tell me how can I figure out the capacitor is bad, if that did not bulge/leak.
                          The caps may not show any sign of bulging, ESR meter and cap meter will be required. At this point we need to locate the standby power supply section first and see how it is hooked up. I will see if Tom has the diagram for this TV.
                          No, he does not have it on his web site.
                          Can you take straight shot pictures of the board, not @ an angle, of both top and bottom side in 4 sections, and the whole bottom side.
                          • Nish
                            • Sep 2013
                            • 124
                            I check the service manual and my power supply board details.... in the service manual says that standby pin 4 and when I look for the pin details of the connector it says A5V_PW. also I checked the power supply board, it details: it mention that pin 14 (A5V). is it same thing? or different pin that I am checking.
                              Is the service manual from Tom's site?
                                The A5V may mean Always on 5V, same as Standby which is there the minute the TV is plugged into the AC outlet.
                                Pin 4 should have steAdy 5VDC.
                                • Nish
                                  • Sep 2013
                                  • 124
                                  yes budm, the services manual from tom site. tom66 gave me the link.
                                  here is the link
                                  http://www.toms-service-manuals.com/...df&mfg=Samsung
                                  so i can track the 5V from A5V connector pin to the 5v chip. am i right? that pin (pin14) also does not stable 5V, it always move up and down as 3.3,2.1,1.4,4.3,so on....
                                  i will try to track today.
                                  • Nish
                                    • Sep 2013
                                    • 124
                                    also i don't have ESR meter, but i want to buy one, so can you tell me which one should i buy so i can use it for any of my future troubleshoot.
                                    • Nish
                                      • Sep 2013
                                      • 124
                                      is this good ESR meter to test my capacitor?
                                      http://www.ebay.ca/itm/New-In-Circui...item4aca4aef2a
                                        It's very overpriced for what it does. You can get much better ones for much, much less.
                                        • x_orange90_x
                                          Samsung UA40J5200AK missing Smart features?
                                          by x_orange90_x
                                          I picked up this TV a couple days ago and it's SUPPOSED to be a smart tv, however it doesnt have any apps or wifi settings to change. I cannot find this EXACT model, it's actually a slight variant that is turning up this information. This is a UA40J5200AKXZN.
                                          The interesting thing about this tv is where it was made. It was made in Egypt. The closest information that I can find that could apply to this model is the following website:
                                          https://www.google.com/url?sa=t&sour...-ua-40j-n5200-...
                                          10-24-2024, 12:29 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
