Vizio VA26LHDTV10T
  • vizionoob
    • Sep 2013
    • 17
    Vizio VA26LHDTV10T
    Hello everyone!
    I have had this Vizio for a while now, but I haven't been using it for almost a year? When I first got the TV, it was working fine, a few months in and I started seeing a blue vertical line at about 1/4 of the screen. I did nothing about it though, I even had warranty then... Some months later, way after the warranty, the screen is now in the condition that it is now.
    There is no sound indication, I have tried to check with my computer and cable, but nothing. The screen starts off grey and then slowly changes to blue, but when I hit the menu button on the side, the top right corner changes green, at what seems to be the default channel indicator, such as AV/HDMI. After that, it just turns blue and has some vertical lines in the center and one on the left. The far left vertical line is the one that first showed up a while ago.
    I have opened the TV up and taken some pictures, hopefully of some good quality. I have checked to see if any of the capacitors have gone bad, but I couldn't find any. I don't know what it can be.
    Let me know if you need a better picture of a certain location on the TV.
    I also took a video of the TV as I turn it on, I AM SORRY ABOUT THE QUALITY, my upload speed is not fast and I did not want to upload a video that was going to take a long time.
    http://www.youtube.com/watch?v=PcwDT...ature=youtu.be
    Re: Vizio VA26LHDTV10T
    It looks like bad panel to me.
    • vizionoob
      • Sep 2013
      • 17
      I removed the white strip from the mobo and when I turn it on, the screen is white. I'm sure you know which white strip, but if not, it's the one visible in images 3 and 4.
      • vizionoob
        • Sep 2013
        • 17
        Actually, I think it may be that strip? I removed it and my screen turns white, no color distortion or anything like that, just white, which I then figure that it can't be the panel? I put back the strip and turned it on, the picture was a little bit clearer and I could actually see the top right of the screen where it says what channel it's on, a few seconds later, a blue pop up showed up saying, "No signal," the message was clear as day, but then it froze...
        Could it be that strip?
          That is the LVDS cable which supply the signals and power to the T-CON board on the LCD panel assembly, when you remove that cable, the T-CON will not have power to drive the LCD, that is why the screen is just glow.
          • vizionoob
            • Sep 2013
            • 17
            Well, I ended up removing the glue/tape that was on the cable, which had folded two corners. I removed it and turned on the TV and it worked. It was the cable all this time... For now, I will leave it as is, but if the problem comes back or something else, I will buy a new cable and go from there.
            • vizionoob
              • Sep 2013
              • 17
              You think I could get redirected to a site that sells the LVDS cable? I've been searching and I cannot find any, I also checked some stores around town and nothing.
              This is what it says on the ribbon:
              P-TWO AWM 20696 E221612 80C 30V VW-1
                I've had this effect on some Chimei V260B1 panels. Different TV but fix may still apply:
                https://www.youtube.com/watch?v=mMo3NBGLwH0
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • Gootch46
                  Vizio E60-c3 blue vertical line (dead center)
                  by Gootch46
                  My Father called me he has a Vizio E60-c3 that's probably 3-4-5 years old but it has a thin blue line running down the center of the screen (photo) I tried a couple things but I'm sure one of you all have seen this already. Been a while since I've been here hope all is well. Thank you in advance....
                  05-26-2023, 05:42 PM
                • otaku_nut
                  Vizio E701i-A3 fixed but now has red vertical line
                  by otaku_nut
                  Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                  08-19-2025, 06:11 PM
                • brad2157
                  Vizio E70-E3 Two white vertical lines
                  by brad2157
                  I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                  Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                  Replacement main board - Boots up fine, but starting...
                  12-13-2021, 05:11 PM
