LG 47v550t possible panel failure?
  • Klinux
    • Jun 2013
    • 12
    I salvage this 47" LED LG LV550T it was displaying black and white lines my initial thought was tab bonding issues or connector ribbons to the tcon and panel.
    I fired it up quickly and noticed that in one of the strips the tv menu was displayed but polarised and backward. I left the set on about to do some checks cables seated properly etc looked back at the screen and noticed the picture completely gone, backlight still on but nothing no lines.
    Tcon chip was ridiculously hot so assuming it had failed I ordered a new tcon which I got for pennies I've installed the tcon and I'm back to where I was with the lines the only difference is the part polarised image comes and goes its still backward.
    There's no real reaction to tapping the screen
    Any advice is much appreciated I'm gonna check out the voltages here's some pics
    Re: LG 47v550t possible panel failure?
    I'd check the panel tab bonds - if one is getting hot it may be defective.
    • Klinux
      • Jun 2013
      • 12
      I'm gonna strip the bezel off and check the tab bonds, what threw me was the fact that the part image of the tv menu and the no signal LG logo was backward.
        Strangely, bad tab bonds have been found to cause inverted images, I am not sure how but they can.
          Yep, I found that inverted image (partial screen) problem on 26" SAMSUNG with bad tab bonding.
          • Klinux
            • Jun 2013
            • 12
            Ok bezel off and tabs exposed.....hmmm its quite clear from looking firstly at the metal surround scorching looking closer at the tabs a couple of the tabs have actually burnt out on some of the lines, looking at it there is staining on the metal surrounds which could be liquid or resin residue from the melted parts of the tabs, possibly gotten in there. Bottom line major panel failure, a real shame it's a nice 3d smart TV. But hey it was free and adds a bit to the knowledge will salvage some boards and scrap the panel.
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • netgearnetgear
              TCL 43S423 TCON OR PANEL FAULTY???
              by netgearnetgear
              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
              08-20-2025, 06:04 PM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
