My First Oscilloscope
Re: My First Oscilloscope
My oscilloscope came today!!!! I'm still waiting on my probes though. I wanted to try and test the oscilloscope. I have something I bought when I was a kid called a function generator (HP 3310B). I want to hook it up to the oscilloscope. Can I use a 6 Foot RG-58 BNC-to-BNC 50 Ohm cable assembly from Radio Shack? The item number is: 2103481. The function generator's output impedance is 50 ohm...-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Yes.
The amplitude will be 2X larger than the signal generator is set to, because the function generator expects the output to be terminated with 50 ohms. However, this does not indicate a fault with the oscilloscope.
Almost every scope also has a "probe compensation" output which can be used to check functionality. It typically produces a 1kHz, 2Vp-p square wave.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
The "probe compensation" output would allow me to test it without having anything hooked up, no probes, nothing? I'm also a little curios about the ground hookup on the scope. I got a manual, I just have to read it. My neurologist put me on some new medicine and it's taking me a bit to get used to it. It's been hard for me to concentrate lately. I will try to read the manual when I get back. I couldn't find anything on the scope called probe compensation. There is a knob that says variables and it reads OFF - Readout - On and in dark letters it says 1x under the off, PROBE under the Readout and 10x under the on. I think that might be it.Yes.
Almost every scope also has a "probe compensation" output which can be used to check functionality. It typically produces a 1kHz, 2Vp-p square wave.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
You will need a probe to connect to probe compensation, hence the name. It's intended for setting the compensation (filter network) of the probe correctly; refer to the documentation which comes with your probe. In the meantime, a wire between the central pin of the BNC and probe comp could do the job.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I think I have a problem with my oscilloscope. I've been reading the manual and there's an up/down lever on my scope called the Selector level. It says in the manual "Move the SELECTOR lever upward and downward to illuminate the desired function lamp. Then adjust the VARIABLE control. The options I'm supposed to be able to select are SINGLE, A/B SEP, DELAY, HOLDOFF, TIME, H POS, MEASURE, Delta Symbol V, Delta T, 1/Delta T, and FREQ. I cannot get it to move off of H POS. Am I doing something wrong or is my scope broken? I just want to calibrate the probes right now. Thanks-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
What trigger mode is it set to? Perhaps try cleaning the control, it could be dirty and not making good contact.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The trigger mode is currently set to Auto, as per the instructions in the scopes manual in the section about how to calibrate the probes. Do you mean try cleaning the Selector lever? I could only do that by ripping it apart. I believe there are supposed to be three settings on this. I think it's a mom-none-mom toggle switch. I think the lever is supposed to stay in the middle until you push it. Pictures of the same unit on the net show the lever in the middle. On mine, there is no middle. It's just up or down. I can see no possibly way of how this would work to make a selection. How would it know where to stop when it's in the up position? If it moves up one at a time, how could I move up twice? I'd have to hit up, down, up. How would it know I didn't want to go down? I'm trying to provide as much info on what's happening as I can. Thanks for the help.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Yeah, it does sound like that control may be faulty which sucks. You might have to send the scope back. Perhaps the control is replaceable, but that would involve tearing into the scope to find a part #.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I was looking at the service manual and I believe the part numbers are as followed:
S1603 Lever - (Hitachi part number) SSL0076 (real part number) AL2S-2M (WITH NOBAZ4004) (description?) I could not find anything with those numbers on the net. I found something that involved genomes. That's not what I'm looking for though.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Sorry to say yes I also think you have problem with your selector switch on you Scope.
That switch is a rocker type switch with center position,so with normal operation your selector switch should be in center position then you can move upward or downward 1-click at time with selector switch returning to center position which allows you to step through your measurement settings,I would contact seller and advise of issue and seek his return policy,that feature not working on the scope would be in my opinion a valuable feature not functioning.Ron Driver,BSEE,CET,ISCET,NESDAComment
Thanks Ron CET. I agree. I had an idea of how it was supposed to work. I've been in touch with the seller and I really don't want to send it back. I'd love to be able to get it working and everything, being my first scope and everything. There's ones on E-bay now, same model and everything for around 300$. This was 115$. I explained everything to him and he found the part I need in his warehouse and is sending it to me. He said he's shipping it out today. Do you guys think this would be an easy repair? I'd have to take the unit apart. The function generator is broke. I think it's the step-down transformer inside. I'm getting 0V on every wire. It was a pain to take a part. Would this be similar? All I have to do is remove the front cover. The service manual shows a diagram of it apart but it's hard for me to follow. If I remember correctly, the quality isn't the greatest. Any ideas? Thanks for the help!
Spork-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
I know this conversation has long since been dead, but I did eventually get the part I needed. The guy I bought it off of went back to the warehouse, found another one, ripped it apart and send me the whole front board (with the selector switch). Thanks.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
by irnardAny advice where can I find micro SMD probe tip for Rigol oscilloscope ? Can't find anything online and factory one is just too fat to fit in some tight spaces on logic board. Thx
Hello.
I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
I want to learn how not to damage it, and I found instructions on the internet obscure.
They talk about ground, earth, floating ground, this, that....
But they don't actually say anything anything useful so far.
I want to know:
Don't connect exactly this to exactly there or it blows up.
For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
I want to know what not to connect... -
by SolomonManAll,
Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor... -
by JimBanvilleN channel mosfets testing as P type?
Working on a smps.
Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
Removed a pair of mosfets marked 1L02AB FDP
26N40 from the circuit.
The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red... -
by EvetsI have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
- Loading...
