I do a lot of LCD/Plasma/DLP repair and I get shocked by power boards frequently, but now I'm worrying that one day I might get shocked really bad, bad enough to kill me. So, how do I fully discharge a power board without waiting days or weeks for its remaining charge to drain.
Power board question
I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Service Menu/Factory Reset Codes for TVs
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: Power board question
You can use 2000 Ohms 25 Watts resistor to discharge the main filter cap that can have voltage up to 400VDC. You do not want to do dead short to discharge the cap due to very high current it can deliver.
You should also plug what ever you are working on into GFCI outlet to protect you or use Isolation transformer.
http://s807.photobucket.com/user/bud...tml?sort=3&o=7Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Thank you so much!I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
after i discharge any big caps should i worry to much about touching traces on the board?I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
After discharging the cap, the use the meter to see if it still has any voltage left on it.
Touching the traces with TV unplugged? If the voltage is no longer present then it's OK.Never stop learning
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
