Nexus NX4203S120 -- Has anyone seen one of these?
  • aaronwt6
    • Apr 2013
    • 855
    • US
    I have a chance to pick one of these up tomorrow for $30. Turns on but has no sound or picture. Problem is I see very little in the way of parts for it. Seems that the 240Hz version is a little more common but I'm worried about finding what I need once I have it in hand. I thought I'd ask first and see if maybe some other brands use the same parts.
    Thanks in advance!
    http://www.rakuten.com/prod/nexus-nx...211822499.html
  • capkid
    • Oct 2010
    • 1339
    Re: Nexus NX4203S120 -- Has anyone seen one of these?
    I figure you've probably moved on from this TV by now. Anyway, I worked on a Nexus awhile back, but it was a 2006 model. The TV had a "sound, but no picture" issue. The internals were mainly LG, and I just had to change out the IPMs.
    LG Plasma Mal-Discharge Correction Service
    • aaronwt6
      • Apr 2013
      • 855
      • US
      I actually picked it up but haven't opened it yet to take a look. It's an LCD and the screen is scraped up pretty good. I may just part it out if I can figure out what's wrong first. I'll post an update this weekend once I get the back removed.
      Thanks!
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Ive got a 50" nexus plasma I havent been able to find any parts for, mine uses an obscure power supply but as I recall the y and x were lg.
        Liberating magic smoke one part at a time
        • capkid
          • Oct 2010
          • 1339
          Yeah, I believe the PSU in the 42" Nexus plasma I repaired was Chinese, and I'd never heard of the manufacturer.
          • gabri2211
            Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
            by gabri2211
            Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
            This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
            This NEXUS connector broke.
            Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
            The Xbox has a power supply that provides 12 volts on all outputs, so the power...
            07-28-2025, 07:13 PM
          • Popalwali
            Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
            by Popalwali
            Hello Everyone,
            I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
            08-25-2024, 11:28 AM
          • vladimir1909
            BIOS SHARE NEXUS MLK_Alienware X16 R2_LA-M41AP R10
            by vladimir1909
            Bios backup...
            11-25-2024, 12:49 PM
          • cardoso42
            Looking for firmware (.bin) for BOE MF245FHB-NF0 or compatible 165hz version
            by cardoso42
            Bom dia amigos. preciso ajudar pra editar uma Firmware. eu tenho alguns monitores com o painel MF245FHB-NF0 de 240hz, porem eles so funcionam em 165hz, em 240hz a imagem fica ruim. preciso de alguem que faça essa alteração na Fw pra eu salvar esses paineis.
            11-17-2025, 04:55 AM
          • audiomodder
            Nexus 5 BATT_ID issue
            by audiomodder
            Hey folks,
            I have a used Nexus 5 motherboard I bought with a ripped out battery connector. Replaced the connector but phone won't start unless VBATT_THERM is disconnected. Then it seems to work fine but of course only shows 0% charge. Did factory reset and it does detect the charger.
            I've tried 3x batteries and they all measure ~68Kohms to ground on that pin.
            To make matters weirder, BATT_ID is grounded on the battery itself, I cannot understand why they even bothered with it connecting to the MCU. VBATT_THERM (i.e. VBAT_THRM) also connects to the MCU.
            04-24-2018, 10:55 AM
