Nexus 5 BATT_ID issue
  • audiomodder
    • Dec 2017
    • 54
    Hey folks,
    I have a used Nexus 5 motherboard I bought with a ripped out battery connector. Replaced the connector but phone won't start unless VBATT_THERM is disconnected. Then it seems to work fine but of course only shows 0% charge. Did factory reset and it does detect the charger.
    I've tried 3x batteries and they all measure ~68Kohms to ground on that pin.
    To make matters weirder, BATT_ID is grounded on the battery itself, I cannot understand why they even bothered with it connecting to the MCU. VBATT_THERM (i.e. VBAT_THRM) also connects to the MCU.
    Schematics (page 223): https://mega.co.nz/#!AoY2gKbA!5fTTr1...p6Od5GPNdUL7Rw
    Thanks for any help!
  • audiomodder
    • Dec 2017
    • 54
    Re: Nexus 5 BATT_ID issue
    traced everything out and I think it must be the GPIO pins on the MCU. cant fix it without painful BGA work :/
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
    • elmark
      HP 15-cw1002ua strange keyboard issue
      by elmark
      HP Pavilion 15-CW1002UA
      S/N 5CD0251CBC
      P/N 7KE54EA
      Hello guys!
      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
      It powers on OK and has no other issues except the following:
      • CAPS LOCK does not work at all
      • Fn button toggles Flight Mode
      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
      • (with SHIFT pressed: 't%' and 'y^' respectively)
      I initially thought it was a keyboard malfunction (internal short, etc.),
      but when I press and hold...
      06-27-2025, 01:10 AM
    • Simone Vergani
      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
      by Simone Vergani
      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
      To assist with troubleshooting, I'm attaching two power circuit schematics:
      • Power
      03-05-2025, 02:25 PM
